GOT a Cel 13... What to do??
Okay, I have a code 13: BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor. What is this and where is this located on my car?
I'm running the afc hack
its in the ecu did you mess with any wiring or anything like that to your ecu. Check any connections and all that you may or may not touched.
just read you using afc hack. It probably that is what is causing it double check everythign make sure you are in the correct range on tha aFc
Its because you have the afc hack, simple as that. Nothing is broken and theres really nothing you can do, its just something you have to live with when your turbo
+ afc + obd2
I've had my CEL on since the day I put the hack in, no ammount of tinkering will get rid of it. Just know that nothing is really broken and it doesn't affect and fuel+timing maps so your safe as far as that code goes.
+ afc + obd2
+ afc + obd2
+ afc + obd2
All damnit, I wanted to get this stupid cel to dispear. It's freakin getting on my nerve. So Eric, you have this code too, how come you never mention it? You think it's b/c we are automatics that we are getting it or is it all obd2?
it's all OBDII. you could remove the light bulb.
But then if you ever got another code besides the 13, you wouldn't know unless your car was sent into limp mode.
Yea ob2 auto or not your just beat and have to live with it. The price you pay for ghetto standalone wannabe really is what it comes down to....
Never mentioned it because its not really that important as much as its just annoying.
