GOT a Cel 13... What to do??
Old Feb 14, 2003 | 09:38 AM
Mr.DC2TurBo's Avatar
Default GOT a Cel 13... What to do??
Okay, I have a code 13: BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor. What is this and where is this located on my car?
I'm running the afc hack
Old Feb 14, 2003 | 09:43 AM
b18bturbo's Avatar
Default Re: GOT a Cel 13... What to do?? (LS-T2001)
its in the ecu did you mess with any wiring or anything like that to your ecu. Check any connections and all that you may or may not touched.
Old Feb 14, 2003 | 09:44 AM
b18bturbo's Avatar
Default Re: GOT a Cel 13... What to do?? (b18bturbo)
just read you using afc hack. It probably that is what is causing it double check everythign make sure you are in the correct range on tha aFc
Old Feb 14, 2003 | 09:57 AM
Tinker219's Avatar
while we are at it, my bros car is flashing a 20...ELD code(electrical load detector).
WTF is this?
Old Feb 14, 2003 | 10:13 AM
I didn't mess with of the until i installed the afc and avc-r. What is consider the correct range. my setting is -33% 1-2rpm and -35 across the rest of the board. preassure 6 in/out. What else you want to know?
Old Feb 14, 2003 | 11:19 AM
shadowdawn's Avatar
Its because you have the afc hack, simple as that. Nothing is broken and theres really nothing you can do, its just something you have to live with when your turbo
+ afc + obd2
I've had my CEL on since the day I put the hack in, no ammount of tinkering will get rid of it. Just know that nothing is really broken and it doesn't affect and fuel+timing maps so your safe as far as that code goes.
Old Feb 14, 2003 | 11:21 AM
Daniel's Avatar
Default Re: GOT a Cel 13... What to do?? (shadowdawn)
+ afc + obd2
yeah, my local shop told me the same thing. they said OBDII computers are real sensitive and fidgety.
Old Feb 14, 2003 | 12:15 PM
All damnit, I wanted to get this stupid cel to dispear. It's freakin getting on my nerve. So Eric, you have this code too, how come you never mention it? You think it's b/c we are automatics that we are getting it or is it all obd2?
Old Feb 14, 2003 | 12:17 PM
Daniel's Avatar
it's all OBDII. you could remove the light bulb. But then if you ever got another code besides the 13, you wouldn't know unless your car was sent into limp mode.
Old Feb 14, 2003 | 12:45 PM
civperc's Avatar
my buddy's 6th gen Civic w/ the hack does the same thing. nothing he can do about it really, the CEL is on, but the engine's going to be fine.
Old Feb 14, 2003 | 01:26 PM
Default Re: GOT a Cel 13... What to do?? (untensadude)
so your friend has the same cel code or just a similar cel check lite that is always on.
Old Feb 14, 2003 | 01:38 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
That's why most people go to obd1 when they use AFC hack.
Old Feb 14, 2003 | 09:59 PM
shadowdawn's Avatar
Default Re: GOT a Cel 13... What to do?? (HybridcivicLS-T)
Yea ob2 auto or not your just beat and have to live with it. The price you pay for ghetto standalone wannabe really is what it comes down to....
Never mentioned it because its not really that important as much as its just annoying.
harshhatch1187
Oct 6, 2006 10:22 PM
V3locity
Aug 1, 2004 03:28 PM
Iceman05
Apr 13, 2004 04:38 AM
red_sir
May 14, 2003 11:18 PM
Lowez
May 30, 2002 07:06 PM
