ctr pistons installed but number 4 cyl. is not burning fuel.
Old Feb 8, 2003 | 11:37 AM
TypeR76's Avatar
Default ctr pistons installed but number 4 cyl. is not burning fuel.
As topic says.
What causes it? I do have spark and #4 piping is warm.
Thanks.
Old Feb 8, 2003 | 11:55 AM
ZygSpeed's Avatar
Default Re: ctr pistons installed but number 4 cyl. is not burning fuel. (TypeR76)
Sounds like you might have a bad or disconnected injector.
Old Feb 8, 2003 | 02:14 PM
sgT's Avatar
sgT
not burning fuel?
whatare the symptoms?
whats the compression test say?
what does the leakdown test say?
Old Feb 8, 2003 | 02:51 PM
TypeR76's Avatar
Default Re: ctr pistons installed but number 4 cyl. is not burning fuel. (sgT)
I pulled #4 wire, the engine idles the same with or without.
I checked the plug and found out that gas is all over the plug.
When I drive around my neighbor, the engine makes loud knocking noise 1k - 4k rpm. My car drives ok on highway. I did not do the comp. test and leakdown test. No tools around. Thanks.
Old Feb 8, 2003 | 03:00 PM
MackSpeed-616's Avatar
that is sad, scary, funny all at the same time.. good luck with the remedy!
Old Feb 8, 2003 | 03:06 PM
ZygSpeed's Avatar
Default Re: ctr pistons installed but number 4 cyl. is not burning fuel. (BustaNutt-616)
Ouch!
A compression tester can be had for quite cheap.
Old Feb 8, 2003 | 03:07 PM
RTW DC2R's Avatar
are these new plugs? wires? distributor cap/rotor?
Old Feb 8, 2003 | 03:09 PM
TypeR76's Avatar
Default Re: ctr pistons installed but number 4 cyl. is not burning fuel. (RTW DC2)
No, I should have replaced them all. I was lazy going to Acura dealer lately.
Old Feb 8, 2003 | 04:04 PM
Chris N's Avatar
Wow, what a great addition to this thread. Very helpful.
Chris - who would check the compression and leakdown also.
Old Feb 8, 2003 | 04:15 PM
sgT's Avatar
sgT
Default Re: ctr pistons installed but number 4 cyl. is not burning fuel. (Chris N)
what else was done to the motor
Old Feb 8, 2003 | 04:35 PM
TypeR76's Avatar
Jun 3, RC 440cc, CTR pistons, Hytech header, Hondata s200 with SGT base map, etc.
Old Feb 8, 2003 | 09:19 PM
sgT's Avatar
sgT
hmmmm
check your plug wires, distributor cap/rotor, injector wiring.
Old Feb 8, 2003 | 09:26 PM
JPP's Avatar
JPP
Might be a long shut but also recheck #4 spark plug gap. When you say you have spark, did you check individual pistons or are you assuming you have a spark at #4 piston.
Old Feb 9, 2003 | 06:54 AM
TypeR76's Avatar
I just rewired #4 injector and my car runs good. Thanks to sgt and everyone.
Old Feb 9, 2003 | 07:12 AM
ZygSpeed's Avatar
1badteg
Jul 16, 2007 02:00 PM
Thepanda
10
Dec 22, 2006 05:55 PM
jt1583
Jun 19, 2005 03:59 AM
FredoSP
Apr 14, 2005 04:50 AM
raene
May 23, 2001 05:25 PM
