how to do compression test?
Old Jun 8, 2005 | 06:23 PM
jt1583's Avatar
Default how to do compression test?
I'm looking at an integra with a salvage title (theft recovery) tomorrow and need to know how to do the compression test. I know how to put the gauge in the spark plug hole but how do i disable fuel and spark? also what size spark plugs do integras use?
and lastly, if the car has a salvage title but still drives like normal i can get it titled/registered/insured right?
thanks
Old Jun 8, 2005 | 06:47 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: how to do compression test? (jt1583)
i just take out all the ignition wires. turn the engine over( with the gas pedal to the floor), until the gauge jumps 3 times. what year/model integra are you buying?
Old Jun 8, 2005 | 07:42 PM
CNSK's Avatar
search on "cspeed racing" google.com tells you step by step
Old Jun 8, 2005 | 07:44 PM
solareclipseauto's Avatar
Default Re: how to do compression test? (CNSK)
take all the spark plugs out test each cylinder indidually
Old Jun 8, 2005 | 08:50 PM
gsrious's Avatar
take out the ecu fuse(this disables the fuel), take out all plugs and test individually at wot.
Old Jun 8, 2005 | 09:07 PM
jadebellyt's Avatar
Default Re: how to do compression test? (red dc2)
Same routine for a wet compression test only with a little oil in each spark plug hole right?
Old Jun 8, 2005 | 09:19 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jt1583 &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking at an integra with a salvage title (theft recovery) tomorrow and need to know how to do the compression test. I know how to put the gauge in the spark plug hole but how do i disable fuel and spark? also what size spark plugs do integras use?
thanks</TD></TR></TABLE>
Here's a link to do a compression test w/ pics: http://www.c-speedracing.com/h...t.php BTW not that hard at all.
Also yes you can get it titled/registered/ and insured.....EXCEPT that it will be a salvage titled car, registered as a salvage car, and insured as salvage car which some car insurance company won't cover.
Old Jun 8, 2005 | 10:45 PM
AK94GSR's Avatar
Default Re: how to do compression test? (Lord Helmet)
here are my easy steps
1:take out all plugs
2:disconnect distributor harness (located on backside of dist)
3:take out fuse from under hood fuse box for fuel
4:connect comp tester
5pen throttle fully and crank over right until needle stops moving
oh and reason why i disconnect dist is because it still is possible for u to damage your ignitor, i've seen it happen so many times if your car has some mileage on it
Old Jun 19, 2005 | 03:59 AM
92integra_gs's Avatar
yea c-speed.com got a lot of good resource for DIY mechanic tech
jtrig
Honda Civic (2001 - 2005)
Jun 2, 2015 03:55 PM
jdm_sai
18
Feb 16, 2010 05:19 AM
JDM00SI
Aug 26, 2005 05:20 PM
zracer240
Apr 24, 2005 08:35 AM
JunIntegra
May 22, 2003 04:12 AM
