Compression test results
Ran a compression test on the ole' B16A today. Here's what I got:
#1 #2 #3 #4
220 210 225 220
225 210 225 225
225 210 225 225
220 215 225 225
Here's what I did:
Pulled all the spark plug wires, disconnected the two-wire connection to the distributor, removed all the fuel injector electrical plugs, pulled all 4 spark plugs, held the throttle at WOT, cranked it over 10 or so times on each test. 4 tests per piston, performed consecutively. Yes, the engine was warm. Piston #2 seemed the most reluctant to reach a stable number; it would steadily climb by 5-10psi increments each time. Probably would've gotten higher numbers for that one if I'd have tried for longer.
I'm pretty pleased; what do you all think?
P.S. The engine made some popping noises occasionally as I was cranking it... really loud, kinda scary... any ideas?
[Modified by raeneshadow, 4:02 PM 5/22/2001]
#1 #2 #3 #4
220 210 225 220
225 210 225 225
225 210 225 225
220 215 225 225
Here's what I did:
Re: Compression test results (raeneshadow)
I get the same popping noises when i test compression on my car. Actually, when you remove the compression tester, smoke comes out of the cylinder. Could be the fuel is getting ignited from the compression (kinda like a deisel maybe?).
[Modified by RioNinja, 10:08 AM 5/23/2001]
New User
Sounds pretty close to mine, I was a little lower though. I had #200 across all four give or take one #. B16 also....
AspectIndustries
08-15-2004 02:31 PM
