minime
Old Jan 30, 2003 | 07:30 PM
96civich22's Avatar
Default minime
ok guys i amd putting a d15 bottom end with a d16y8 head into a 96 civic, what do i do about the crank sensor ???? obd2 calls for a crank sensor but on the d15 bottom end doesnt have one. will an oil pump from a 96 fit on a 92-95 bottom end cause if it will i could do that and put the sensor on, i just need some advice on this??? help me guys..
Old Jan 31, 2003 | 06:48 AM
96civich22's Avatar
Default Re: minime (96civich22)
can no one help me,???? man this place sucks???? so you all are basicly saying that when you did a minime you all were like **** the crank sensor??? come on guys i need some help
Old Jan 31, 2003 | 08:21 AM
donesixer's Avatar
In everyone's defence, I doubt anyone knows for sure. The d15 is not the typical bottom end to use.
Options:
1) Try an OBD1 distributor, and do some wiring harness mods (would not recommend)
2) Try mounting a sensor on the d15 and hope that it fits
3) Scrap the d15 for a d16, stronger bottom end anyway
Where is the d16 that was in there originally?
Old Feb 1, 2003 | 02:41 PM
96civich22's Avatar
ttt i need help
Old Feb 1, 2003 | 03:22 PM
splitime's Avatar
I'd just say go with a stock p28 and wire up what you need to. Not sure why'd you want to keep it odb2. Then you dont have any worries with a crank sensor and only 1 o2 to worry about.
Old Feb 3, 2003 | 07:31 AM
donesixer's Avatar
Default Re: minime (splitime)
Yup, I'm with splitime...
Old Feb 3, 2003 | 12:11 PM
TEG98's Avatar
Default Re: minime (donesixer)
have you tried the tech forum. Integras use B series Engines. You might find people more knowledgeable about D series in another forum.
Old Feb 3, 2003 | 02:34 PM
splitime's Avatar
Default Re: minime (TEG98)
This is the Tech Forum.......
hugens26
Sep 19, 2010 03:33 PM
tnxx
Dec 7, 2009 05:43 PM
1xfastxhatch
Nov 1, 2009 08:44 AM
H2BSTUPID
Mar 20, 2009 06:41 PM
HondaPartsHero
Feb 1, 2006 08:17 PM
