what little things to buy when swapping?
Old Jan 24, 2003 | 09:23 AM
deviant1's Avatar
Default what little things to buy when swapping?
I just found out you need to use new snap rings on the end of the axles that go into the tranny and you need to use new cotter pins on the castle nuts. What extra little things like these need to be replaced when swapping a b18 into an EK? I want to be prepared as much as possible when i do the swap.
List:
cotter pins
snap rings
timing belt
water pump
spark plugs and wires
rotor
i think new bolts for the engine and tranny mounts. i recall it saying replace those in my helms manual for my civic.
axle nuts
electrical connections
anything else?
[Modified by deviant1, 4:48 PM 1/24/2003]
Old Jan 24, 2003 | 10:53 AM
MLogan's Avatar
Default Re: what little things to buy when swapping? (deviant1)
Don't forget fluids and possibly new clutch.
Old Jan 24, 2003 | 11:07 AM
nsxmatt's Avatar
Default Re: what little things to buy when swapping? (MLogan)
Radiator hoses and clamps, possible fuel line depending on what model you have now.
Old Jan 24, 2003 | 11:12 AM
wm5holla's Avatar
that was a great question to ask,, i hope you get many replys back! u mite need nuts and **** just case u strip em
Old Jan 24, 2003 | 11:40 AM
jmm96gsr's Avatar
Default Re: what little things to buy when swapping? (wm5holla)
dont forget food and beer!! pins to connect wires to the ecu and wires, connectors or a soldering gun.
[Modified by jmm96gsr, 3:41 PM 1/24/2003]
Old Jan 24, 2003 | 03:34 PM
drvfast's Avatar
axle nuts in case u messed them up in my case i had to buy some
Old Jan 24, 2003 | 03:57 PM
deviant1's Avatar
Default Re: what little things to buy when swapping? (drvfast)
any other bolt, nuts, rings, gaskets, etc....?
Old Jan 24, 2003 | 05:06 PM
Integra-T's Avatar
Distributor cap, brakleen (LOTS), feeler gauges, anti-seize, extra vacuum line, pcv valve, oil filter. Hell if it were me I would change all belts as well including timing. Do whatever is going to be a bitch once the motor is in the car.
Old Jan 26, 2003 | 09:52 PM
H22EK's Avatar
Default Re: what little things to buy when swapping? (Integra-T)
Lots of (and smokes)!
new_climber
Mar 22, 2008 03:21 AM
kinkyintegra
Dec 16, 2006 08:14 PM
bmoua
30
Oct 16, 2006 12:14 PM
deviant1
Mar 12, 2003 11:22 AM
pennies_hatchie
Aug 28, 2002 12:07 PM
