turbo oil return line leaking
I just installed my turbonetics t3/t4 turbo and I am having a problem with the oil return line. It is leaking from the top of the steel breaded hose. I want to know if anyone has used anything besides steel breaded hose? Everytime I try to tighten a hose clamp on it they all break. I have them on as tight as I can get them with out them breaking. Any suggestions would help.
I tapped the pan and it has a nipple on the turbo. It is just a 10an steel breaded hose. It doesn't have anything to thread onto or anything like that. Let me know if you have any other suggestions.
earls fittings and line here
edit:
make sure its not leaking from the flange, maybe from the gasket?
you may want to invest in earls fittings, they are top notch
[Modified by B18EG6, 7:40 PM 1/20/2003]
edit:
Smarter than you
earls fittings own though. thats the best way to do it.
[Modified by DIRep, 4:36 PM 1/20/2003]
VSM EXtasy
Oct 6, 2009 12:19 AM
