Help with oil leak
Old May 14, 2003 | 01:15 PM
mafioso102's Avatar
New User
Default Help with oil leak
I have a leak from my oil return line . The welds appear fine, i believe it is from the turbo. I have a rubber hose connected to the fitting, it appears to leak where it connects to the oil pan and the turbo, coming out from underneath the rubber hose. The connections are not threaded, so I cant use a SS line. I have basic clamps right not, will better clamps help the leak? Also, is there some sort of high temp silicone I can put around the hose connections that will help with the leak?
Old May 14, 2003 | 01:26 PM
gsrhunny's Avatar
Default Re: Help with oil leak (mafioso102)
I had the same problem. They just replaced the rubber hose with a steel braided one and used regular clamps.
Old May 14, 2003 | 03:59 PM
mafioso102's Avatar
New User
Default Re: Help with oil leak (gsrhunny)
How did you connect the steel braided line to the oil pan return outlet? Was the outlet threaded?
Old May 14, 2003 | 06:10 PM
gsrhunny's Avatar
No it wasn't threaded. They just used clamps.
Old May 14, 2003 | 06:15 PM
RyanAutry's Avatar
TK028 (http://www.jgstools.com/turbo/t3t4oil.html)
T3 & T04 Outlet- 1/2" NPT
$11.99
EAR-981610
-10 AN to 1/2 in. NPT blue, straight, male pipe thread to AN adapter ...
$4.50
AER-FCA1003
-10 AN, 3 ft., braided stainless steel hose ...
$19.95
(2) EAR-300110
-10 AN straight, blue and red anodized Auto-Fit hose end ...
$8.50
EAR-967110
-10 AN, male, steel, natural finish, weld fitting ...
$7.69
All Part numbers are from summit except the turbo oil outlet.
If you want 45º ends on the hose replace EAR-300110 with these
(2) EAR-304610
-10 AN 45 degree bent tube, blue and red anodized Auto-Fit hose end, for dry sump, remote oil filter line appl...
$18.50
Old May 14, 2003 | 06:23 PM
RyanAutry's Avatar
Default Re: Help with oil leak (RyanAutry)
Send Flamenco-T a PM and he can get you the above oil return line at a killer price.
PM him here:
https://honda-tech.com/zerouser...=5619
jacob4lester
Feb 16, 2010 08:36 PM
civicsaremean
Jul 10, 2007 07:37 AM
D15Bbigred
Mar 1, 2007 07:36 PM
gsrcivict
May 29, 2003 09:41 AM
jdmtegxsi
Jan 20, 2003 03:36 PM
