Kaaz or Quaife?
Old Jan 13, 2003 | 07:21 PM
1506's Avatar
Default Kaaz or Quaife?
I have a Kaaz lsd from a GSR tranny that I just bought. The Kaaz need to be rebuilt and the cost is half the price of the quaife. Which one performs better for drag racing. What are the pros and cons on them. I want something that will last but don't want to break the bank.
Old Jan 13, 2003 | 07:30 PM
charjacq's Avatar
New User
Default Re: Kaaz or Quaife? (1506)
I believe they are both cluch type LSDs. Quaife is definitively better. Sorry, no pros and cons.
Old Jan 13, 2003 | 07:42 PM
Shawn C's Avatar
In The Garage
Default Re: Kaaz or Quaife? (charjacq)
yeah, quaife will last longet and hold more, and an LSD just does its job (no pros an cons).
Old Jan 13, 2003 | 08:56 PM
1 2 NV's Avatar
bzzz wrong answer. quaife is gear driven and kaaz is clutch. do not fix the kaaz. i took mine out in only 3 months. POS.
Old Jan 13, 2003 | 09:20 PM
Kataku2K3's Avatar
Default Re: Kaaz or Quaife? (hondaatwsu)
Quaife , no doubt about it... Latez
Old Jan 13, 2003 | 09:25 PM
texan's Avatar
Default Re: Kaaz or Quaife? (Kataku2K3)
technically speaking, a clutch type limited slip will have superior function to a geared ATB. I have no direct experience with either in any of my cars, but I have driven a Kaaz equipped vehicle and thought it felt great. Many S2000 owners swear by them over the stock Torsen. One downside though is some small additional noise, which is especially noticable on fwd vehicles.
Old Jan 14, 2003 | 06:14 AM
Jeff C's Avatar
From my understanding: With Kaaz, you have to drive in figure-8's for 30min to break it in and you have to change the fluid every so often. With Quaife, you just slap it in and go forever.
I have no experience with either, but I know where my money is.
[Modified by Jeff C, 10:15 AM 1/14/2003]
Old Jan 14, 2003 | 10:36 AM
CHEETAH's Avatar
I never had bad experiences with the KAAZ lsd, however I know other people have.
Anyway, I use their products and prefer it over the geared type ones... but the clutch binding is not for everyone, however it will out perform the Quaiffe or ITR LSD as I have experienced both.
The clutch types are generally the best, look at mugen and spoon who sell race parts for honda cars, they both made the LSDs clutch type.
Greg
Old Jan 14, 2003 | 03:35 PM
1506's Avatar
Default Re: Kaaz or Quaife? (CHEETAH)
I cracked the kaaz open last night and found that the spider gears were broken. The clutch plates don't look worn to me. I call kaaz today and they told me that the ealier units that they made for honda/acura vehicles sometimes had that problem. He said that they recently made better spider gears for the unit. I'm going to send it to them to get it repaired and see how it will work for me. He told me that he would just charge me for the gear and replace everything else in the unit for free, no labor charge too.
One other question, how should I set it up. Should I have it lock up at 100% or should I allow some slip in the LSD. What would work best.
Old Jan 14, 2003 | 07:28 PM
satan_srv's Avatar
I have a kaaz it's awesome...I don't mind the noise...I think it's pretty neat-o personally...
Old Jan 15, 2003 | 12:45 AM
SuperSH's Avatar
Default Re: Kaaz or Quaife? (satan_srv)
Woulden't the Quaife be good/better suited for auto-X style driving or at least better than a clutch type, on/off style diff.?
Old Jan 15, 2003 | 12:59 AM
hondaswaper's Avatar
Default Re: Kaaz or Quaife? (SuperSH)
Quaife will replace there Diff no Qs asked if it ever fails
Old Jan 15, 2003 | 05:27 AM
CHEETAH's Avatar
[QUOTE
One other question, how should I set it up. Should I have it lock up at 100% or should I allow some slip in the LSD. What would work best. [/QUOTE]
what style of racing ? 100% is pretty hard, gotta have some play in there if you're doing any sort of curve racing or stret driving at least do the 1.5 way lockup.
greg
Old Jan 15, 2003 | 12:54 PM
RagingAngel's Avatar
I've had both..KAAZ and now the Quaife...
for my own purposes, I prefer the Quaife
But I side with Cheetah and must say the KAAZ is superior in performance to the Quaife.
The downside is its expensive oil appetite and frequent need to change it. The Quaife also weighs more than the KAAZ.
It's by far the heaviest unit if you compare ITR vs. KAAZ vs. Quaife.
But Quaife you can use "cheap" Honda MTF or in my case GM syncromesh and never worry about breaking it.
For my purposes, mostly being on the street, Quaife was my choice because I could never put the KAAZ to good use without endangering the lives of others....hehe...
Old Jan 15, 2003 | 03:01 PM
1506's Avatar
[QUOTE
greg
I will be strictly drag racing. I think I will get it set up with a little slippage for less stress on the rest of the drivetrain. Thanks for the help.
00 Si greddy turbo
built bottom end
260 whp and 195 lbs of torque at 10PSI
still running the "BLUE BOX"
440cc inj. and hondata soon.
Old Jan 15, 2003 | 03:45 PM
igyloo's Avatar
What about the ITR LSD?
Old Jan 15, 2003 | 06:53 PM
95c1v1cs1's Avatar
Default Re: Kaaz or Quaife? (igyloo)
I got a Quaife and i love it. It sticks really nicely to the ground. Around turns and off the go.
quaife gets my
Old Jan 16, 2003 | 12:01 PM
Jeff C's Avatar
I have been told that they can only handle about 300hp so anything above that would probably be pushing it. However, I have also heard of people putting down 400hp with them also. :shrugs:
If you are going to be happy with 250hp or less then I would say get the ITR unit.
littlerichie34
Feb 27, 2009 01:37 PM
ExtendedPurple
Aug 17, 2005 07:07 AM
Lucias_D
Feb 7, 2005 06:20 PM
Kaizen
Jul 16, 2003 07:52 PM
KekeK-18
Oct 22, 2001 01:23 AM
