check engine light?? VSS(vehicle speed sensor)
Old Jan 8, 2003 | 03:41 PM
fukaintmuven's Avatar
Default check engine light?? VSS(vehicle speed sensor)
so thats what it is.... its engine cel # 17. but it says vehicle speed sensor circuitry.. can anyone tell me or know what, why and how they go bad. How can i fix this problem???
Old Jan 8, 2003 | 04:33 PM
tnbigdawg's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (fukaintmuven)
maybe a wire got cut somewhere. but what car and engine???
Old Jan 8, 2003 | 08:10 PM
turbod16y8's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (tnbigdawg)
same thing happened to mine. it was a blown fuse that was causeed by a short in the o2 sensor. the speedometer didnt work when the fuse blew.
Old Jan 9, 2003 | 02:12 PM
Default Re: check engine light?? VSS(vehicle speed sensor) (turbod16y8)
its an ls/vtec in a coupe.............. hey my vtec isnt engaging..... is it due to the VSS being bad
Old Jan 9, 2003 | 02:13 PM
DAMNit i need VTEC sum1 help
Old Jan 9, 2003 | 02:18 PM
tnbigdawg's Avatar
what year car and what ecu you running?
Old Mar 3, 2003 | 05:37 PM
M.A.R.C.'s Avatar
hey... this is happning to my car... what did you do to address the problem? was it the actual sensors that were messed up? or just the wiring?
Old Mar 3, 2003 | 05:40 PM
fowler!'s Avatar
bad vss = no vtec
My sensor on my wiring harness got some corosion in it. If that's your problem, you can find a another plug, or throw some coca-cola on it. It will eat away at the funk and serve as a temporary fix
Old Mar 3, 2003 | 05:41 PM
Patch's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (CivicRyda2k)
Hmm, I'm throwing code 17 too. But, my speedo works and my VTEC still works. Although I'm almost sure that my speedo is off.
Old Mar 3, 2003 | 07:18 PM
Default Re: check engine light?? VSS(vehicle speed sensor) (CRX PAT)
change ur sockets..... water or other fluids might have cause corrosion and no contact is made.... code 17 or bad vss+no vtec
Old Mar 3, 2003 | 07:23 PM
JDMH22HATCH's Avatar
Make sure the wires are tight on the harness. I had one of the wires come loose and same thing happened to me. Also make sure harness is connected (on differential side).
Old Mar 4, 2003 | 07:27 AM
iTR.EX's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (JDMH22HATCH)
what if i am getting vtec, my tach works, along w/everything else(temp/gas), could it be the head on the speedometer itself? hence time to replace the unit?
Old Mar 5, 2003 | 08:37 AM
junya16's Avatar
what fuse was it?
Old Mar 5, 2003 | 09:52 AM
turbod16y8's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (junya16)
it was the alternator sp sensor fuse under the dash. it cause my CEL to come on and my speedometer to not work.
Problem: o2 sensor wires were cut and touching the ground of the car.
Old Mar 5, 2003 | 10:12 AM
iTR.EX's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (iTR.EX)
bump?
Old Mar 5, 2003 | 08:07 PM
iTR.EX's Avatar
t
Old Mar 5, 2003 | 08:17 PM
freakin_eLRoD's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (fowler)
bad vss = no vtec
Same thing happened to my vss, except the corosion got so bad that it ate away at the actualy pins on the connectors. Hopefully it didn't get that bad.
Old Mar 6, 2003 | 03:58 AM
Caveman74's Avatar
Default Re: check engine light?? VSS(vehicle speed sensor) (powerBan.est1990)
I have been having the same problen , replaced VSS and it still jumps and works half the time. If it was the alternator fuse wouldn't it not work if it was blown?
Old Mar 6, 2003 | 11:17 AM
still_learning's Avatar
Ya, same thing happened to me with stock single cam, but it was just a loose wire on the speed sensor plug.
Mauro87
13
Jul 15, 2012 05:16 AM
brad22486
Jun 1, 2012 03:54 PM
vicki
12
Oct 22, 2008 10:26 AM
ricearoni56
Feb 11, 2008 05:10 PM
B20-T
Aug 1, 2002 01:06 PM
