help cel light came on
Old Aug 1, 2002 | 12:25 PM
B20-T's Avatar
Default help cel light came on
once in awhile these two cel come on and off..its number 17 (speed sensor) and 22(vtec sel)..when the speed dont work the 22 comes on..what do you guys think could be causing the problem?i hate this cel light because when it comes out , when i hit vtec range my car bogs outs..please help me.thanks
Old Aug 1, 2002 | 12:28 PM
badCRX's Avatar
New User
Default Re: help cel light came on (B20TURB0)
It may have to do that the ECU has to be over a certain speed before it will engage VTEC. I don't think it would throw that code though, but just not engage VTEC. I would say to check the VSS and the wires leading to them so that they didn't get pulled out of the sensor. That may solve both problems for you.
Double check your oil level too. Too little can cause your oil pressure to not be enough to engage VTEC with.
Old Aug 1, 2002 | 12:29 PM
B20-T's Avatar
Default Re: help cel light came on (badCRX)
oil level fine..do u think if the speed sensor not working it will throw a 22 also?
Old Aug 1, 2002 | 01:00 PM
tararan's Avatar
check the fuse for the speed sensor... my friend had that problem, all it was a blown fuse and fix all his CEL... do you have o2 sensor or are you using that box i forgot what it was called....
Old Aug 1, 2002 | 01:06 PM
B20-T's Avatar
Default Re: help cel light came on (tararan)
i am using an 02 sensor..what fuse would the speed sensor be?
stehigs321
15
Mar 1, 2019 05:16 PM
brad22486
Jun 1, 2012 03:54 PM
jvg
May 27, 2008 12:09 PM
kwil666
Mar 15, 2005 08:39 PM
fukaintmuven
18
Mar 6, 2003 11:17 AM
