check engine light?? VSS(vehicle speed sensor)
so thats what it is.... its engine cel # 17. but it says vehicle speed sensor circuitry.. can anyone tell me or know what, why and how they go bad. How can i fix this problem???
Re: check engine light?? VSS(vehicle speed sensor) (tnbigdawg)
same thing happened to mine. it was a blown fuse that was causeed by a short in the o2 sensor. the speedometer didnt work when the fuse blew.
Re: check engine light?? VSS(vehicle speed sensor) (turbod16y8)
its an ls/vtec in a coupe.............. hey my vtec isnt engaging..... is it due to the VSS being bad
1 Post
Re: check engine light?? VSS(vehicle speed sensor) (fukaintmuven)
My sensor on my wiring harness got some corosion in it. If that's your problem, you can find a another plug, or throw some coca-cola on it. It will eat away at the funk and serve as a temporary fix
Re: check engine light?? VSS(vehicle speed sensor) (CivicRyda2k)
Hmm, I'm throwing code 17 too. But, my speedo works and my VTEC still works. Although I'm almost sure that my speedo is off.
Re: check engine light?? VSS(vehicle speed sensor) (CRX PAT)
change ur sockets..... water or other fluids might have cause corrosion and no contact is made.... code 17 or bad vss+no vtec
Re: check engine light?? VSS(vehicle speed sensor) (JDMH22HATCH)
what if i am getting vtec, my tach works, along w/everything else(temp/gas), could it be the head on the speedometer itself? hence time to replace the unit?
Re: check engine light?? VSS(vehicle speed sensor) (junya16)
it was the alternator sp sensor fuse under the dash. it cause my CEL to come on and my speedometer to not work.
Problem: o2 sensor wires were cut and touching the ground of the car.
Re: check engine light?? VSS(vehicle speed sensor) (iTR.EX)
Re: check engine light?? VSS(vehicle speed sensor) (fowler)
bad vss = no vtec
bad vss = no vtec
Re: check engine light?? VSS(vehicle speed sensor) (powerBan.est1990)
I have been having the same problen , replaced VSS and it still jumps and works half the time. If it was the alternator fuse wouldn't it not work if it was blown?
Mauro87
13
07-15-2012 05:16 AM
