Question abt speed sensor
got question for 00 em1 since my speed sensor stop working my vtec dont pop thats wat i think, just want to know my vtec dont on cuz of the speed sensor or its some other problem?
Re: (vicki)
If the ECU is not getting the signal from the sensor the check engine light will be on. With that code on the VTEC will not work. You need to figure out why the speed sensor isnt working.
Re: Question abt speed sensor (vicki)
Vtec won't work if the speedometer isn't working.. it isn't getting the right signal to come in cause the speedometer isn't working.
Re: (Sr420Det)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det »</TD></TR><TR><TD CLASS="quote">Actually I believe it does still work if the speed sensor is out but probably not with the o2 being out.
at least on a 95 ex </TD></TR></TABLE>
nope won't work without the speedometer working. It will work if the o2 is out though.
I have the same problem with my sisters car right now (00 EM1). This is exactly what is going on. The speedometer isn't working, as well as Vtec. CEL is on and said the speedsensor isn't working.
Anyone know how much the sensor cost? Is it hard to change the sensor?
The signal comes from the cluster. The older EFs that had cable clusters still put out an electrical signal for the ECU fyi.
If your VTEC pops then there is something wrong.
edit: VTEC requires a certain speed, oil pressure, and coolant temperature for engagement
Modified by drSquish at 2:39 PM 10/22/2008
Re: Question abt speed sensor (Jet.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet. »</TD></TR><TR><TD CLASS="quote">Anyone know how much the sensor cost? Is it hard to change the sensor?</TD></TR></TABLE>
I am not sure about how much they cost anymore, I think its around $100, but not sure, and no it isn't hard to change, it has 1, 10mm bolt tightening it down after you get the bolt out twist the sensor and it should just pull right out.
Re: (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish »</TD></TR><TR><TD CLASS="quote">The signal comes from the cluster. The older EFs that had cable clusters still put out an electrical signal for the ECU fyi.
If your VTEC pops then there is something wrong.</TD></TR></TABLE>
True, I don't know too much about the Ef's, i've never really messed with one of those, but yeah the eg's and ek's have the signal coming from the speedometer and all for the vtec to come in.
mrpaccmann
02-08-2010 12:41 PM
686_ef
11
04-06-2005 05:57 PM
madd
08-10-2004 11:35 PM
