last Question, what plugs for boost
Old Dec 30, 2002 | 12:28 PM
hybridb18's Avatar
Default last Question, what plugs for boost
ok, this is the last thing i need. i did a search but couldnt find anything. do i run colder plugs or hotter??? With boost, gonna be runnin like 9psi on LS. i also have msd ignition. Are there any brands of plugs that are better to use?? or should i just stick with ngk? Thanks Oh also, how much should i retard the timing, i thought i saw something like 1 degree for every psi of boost. not sure.
Old Dec 30, 2002 | 12:35 PM
RAWB's Avatar
Default Re: last Question, what plugs for boost (hybridb18)
NGK BKR7E's, here.
Old Dec 30, 2002 | 12:37 PM
SIK IN DA HED's Avatar
New User
Default Re: last Question, what plugs for boost (integracon)
if you have a b18b... BCPR7ES11s
i would suggest retarding your stock timing at least 1~2 degrees.
Old Dec 30, 2002 | 09:26 PM
hybridb18's Avatar
Default Re: last Question, what plugs for boost (dlplayboy)
ttt
Old Dec 30, 2002 | 10:08 PM
PrecisionH23a's Avatar
ngk bkr7e-11's. part number 1283 at advanced auto parts
end of story.
Old Dec 30, 2002 | 10:12 PM
Brad's Avatar
does it matter if it's BKR7E or BCPR7E for a b18b/b20?
Old Dec 30, 2002 | 11:21 PM
hybridb18's Avatar
so pretty much i should go about 2 degrees colder on the plug, what about the timing??
Old Dec 31, 2002 | 02:49 AM
VaporTrail's Avatar
New User
8-10 degrees should be adequate, so long as you are going the FMU route.
We have been using the NGK Iridium plugs for some time now with great success. One set has lasted without fouling for nearly 8months. A switch to NGK coppers resulted in - no power gain/loss, but they didn't last very long. I recommend them, but not the Denso's. They are alarmingly fragile
Old Dec 31, 2002 | 04:37 AM
Tony Starks's Avatar
Default Re: last Question, what plugs for boost (VaporTrail)
8-10 for 9psi of boost? Isn't that a little much? I'm not trying to start a pissing match, but wouldn't it be 7-8 degrees?
Old Jan 10, 2003 | 10:48 AM
mos's Avatar
mos
Default Re: last Question, what plugs for boost (Brad)
I just grabbed both those plugs to compare them. They are exactly the same on the side the combustion chamber sees. The only difference is the BKR type plugs are slightly shorter on the side the wires hook up to. I'm talking like 1mm here, so maybe your plug wires will fit slightly worse on one than the other, but for all intents and purposes they are the same plug.
fast93accord
May 16, 2005 03:31 PM
r7
Aug 26, 2003 05:18 AM
97F22B2
Jul 5, 2003 10:45 AM
Sh4rky
Apr 2, 2002 01:34 AM
echo999
Oct 17, 2001 06:07 AM
