ODB 0 to I conversion
Old Dec 29, 2002 | 08:02 AM
shingles's Avatar
Default ODB 0 to I conversion
Can someone please point to a site which has ODB 0 to I conversion? I've done a search on this site and didn't find much.
Thanks,
-S
Old Dec 29, 2002 | 08:56 AM
NateTEG95's Avatar
Default Re: ODB 0 to I conversion (shingles)
That canversion is going to be treaky. You are going to have to mount sensors on the block and change your O2 sensor.
Old Dec 29, 2002 | 09:00 AM
LOtownNateB's Avatar
Call Payn Tech they have the stuff to do it . COM" TARGET="_blank">www.PAYNTECHNOLGIES.COM
[Modified by LOtownNateB, 6:00 PM 12/29/2002]
Old Dec 29, 2002 | 09:24 AM
shingles's Avatar
Default Re: ODB 0 to I conversion (LOtownNateB)
Well, I've got a 1st gen B16. I want to run Hondata after I boost so I am considering conversion to ODBI. I know Hondata can do ODB0 PR3, but that ECU needs two O2s and I'd have to run open loop all the time... that's not going to work well for me because I actually want to drive the car on the street.
Asides from the harness and a new distributor, I am curious what addition wiring might need to be done.
Thanks,
-S
Old Dec 29, 2002 | 02:34 PM
Call Payn Tech and ask for Matt or Tom. they will get you set up with a forward date harness and hondata . Payn Technologies # 248-362-0283
Old Dec 30, 2002 | 11:59 PM
integls95's Avatar
go to
http://www.urbanimports.org, talk to jesse he makes a conversion kit
Old Dec 31, 2002 | 05:06 AM
Payntech's Avatar
We have a kit that includes a new OBDI distributor, the forward date harness, and a 4-wire O2. You will have to do a little bit of wiring, but it is well worth it.
We are one of the largest Hondata dealers in the country.
Give Matt or Myself a call and we can get you the components and technical assistance to make the conversion and smooth as possible.
Thanks,
Tom
Old Jan 9, 2003 | 06:49 PM
shingles's Avatar
Default Re: ODB 0 to I conversion (Payntech)
Thanks Tom. I'll get in touch with you guys.
-S
Old Jan 9, 2003 | 09:08 PM
JHill's Avatar
How do you guys handle the ELD? Do you also need to get a new alternator that the ECU controls, or does that even give a CEL code if it is not connected?
I did the conversion already, but for the AEM EMS, so the ELD issue was nil.
Old Jan 9, 2003 | 09:29 PM
EFing8's Avatar
Default Re: ODB 0 to I conversion (JHill)
PM to Blown90Hatch. Usually the EF forum is a good forum to post this question, but do a search on HT and you will find lots of info
Old Jan 10, 2003 | 05:12 AM
Payntech's Avatar
Default Re: ODB 0 to I conversion (EFing8)
Hondata will allow you to disable the ELD.
Tom
Old Jan 10, 2003 | 09:18 AM
Zeus Zore's Avatar
Tom
that would be nice !! cause got a USDM ELD in my 95 (E)SI (euro model)
and always have a error code for ELD .. not that is dones not run right !! but just annying knowin it is there...
Supa Troopa
Engine Management and Tuning
Jan 19, 2012 05:51 PM
SkertySkerty
Jul 2, 2007 05:24 PM
MyWhiteCivic
Jan 30, 2003 08:58 PM
7rrivera7
Nov 16, 2002 01:22 AM
7rrivera7
Nov 15, 2002 04:10 PM
