OBD 0 to 1 Conversion, Code 20 ELD?????
Old Jan 10, 2003 | 09:44 AM
omahaturbocivic's Avatar
Default OBD 0 to 1 Conversion, Code 20 ELD?????
I swapped a 93 b18a with an obd1 pr4 ecu into a 90 civic std. The ecu is throwing a code 20 for electronic load detector. I checked and according to the wiring conversion guide i used to wire in the ecu the eld wire is hooked up right. Does anyone know where the eld is located in the civic std or if there even is one? Is there any voltage I can use instead at the ecu to prevent the code????? Any help is greatly appreciated! Thanks in advance!
[Modified by omahaturbocivic, 12:44 PM 1/10/2003]
NoName487
May 12, 2011 05:01 PM
pettyboy69
Mar 30, 2010 09:48 AM
shivern
Mar 6, 2005 03:23 PM
omahaturbocivic
Jan 10, 2003 01:03 PM
