can you weld aluminum to steel?
Old Dec 28, 2002 | 11:59 AM
Wo-Nelly's Avatar
Default can you weld aluminum to steel?
I got a steel bov flange and i was wondering if it can be welded to a aluminum inatke pipe. I thought I was going to use all steel but I kinda just want to re use my intake pipe. Will it work?
Old Dec 28, 2002 | 12:00 PM
Brad's Avatar
Default Re: can you weld aluminum to steel? (GottaLude)
you can't weld it, but you can braze them together.
Old Dec 28, 2002 | 12:16 PM
Wo-Nelly's Avatar
Default Re: can you weld aluminum to steel? (Brad)
braze them together?
Old Dec 28, 2002 | 02:11 PM
BigMoose's Avatar
The simple and cost effective answer here is .... No.
For academic interest only....aluminum and steel can be "welded" explosively in thin sheets. Its called "welding" but basically the atoms get happy with each other in microscopic ways. It does not stay together long, because of the drastically dissimilar coefficients of thermal expansion of the two metals.
So peruse the catalogs for an aluminum flange, or fire up your CNC mill and make a few out of a nice weldable Aluminum alloy. Then you can sell the steel one and meet someone new.
Regards, .. and Happy Holidays!
BigMoose
Old Dec 28, 2002 | 04:59 PM
91CivicSi's Avatar
Yes. Here's part of my AEM intake piping welded to a mild steel pipe. It's an ugly weld but it's held up for 2 months now.
[Modified by 91CivicSi, 9:01 PM 12/28/2002]
Old Dec 28, 2002 | 05:21 PM
Phoenix GSR's Avatar
you could jb weld it on, it would hold fine for that app, but an aluminum bov flange wont cost much...
Old Dec 28, 2002 | 06:49 PM
cock head's Avatar
Default Re: can you weld aluminum to steel? (Phoenix GSR)
First some how try to rivit the flange to the pipe and then braze it. IF you cant rivit it just braze it you will be fine.
Old Dec 28, 2002 | 06:50 PM
cock head's Avatar
First some how try to rivit the flange to the pipe and then braze it. IF you cant rivit it , then just braze it you will be fine.
EK k kay
Jan 28, 2006 09:58 PM
nekoabandoned
Nov 26, 2005 02:49 PM
rice a roni
Welding / Fabrication
17
Apr 8, 2005 07:58 AM
pub
Mar 24, 2003 04:01 PM
Snafu-Si
Apr 29, 2002 05:10 PM
