stock DSM bov flange is steel?
The stock 1g dsm bov flange is steel right? So I can just cut it off the pipe and weld it to any type of steel intercooler piping?
Re: stock DSM bov flange is steel? (EK k kay)
Should I cut where the flange meets the pipe or cut some of the pipe off to weld onto the new pipe?
get a piece of steel...a short piece of pipe..and some hole saws...and make you own...thats what i did...20 min of work...aint the best solution...but it worked....funciton over fashion!
Re: (drumking15)
So I can't weld it to my mild steel piping? I mean the DSM pipe is steel as well and the flange is welded to that and looks fine.
Re: (EK k kay)
I cut mine off stuck it on a piece of 2.25 aluminized exhaust tubing that I hammerd flat just a little so it would sit nice, welded around the inside nicely so it wasn't a huge wide bead, drilled out the center then die grinded it a little bigger. Welds up real nice its cast steel not cast iron.
