oil feed line running underneath the mani
i have my oil feed line running underneath my manifold, really close to it and close to the block. is this bad? it's a stainless line, but i'm still worried.
i ran mine the other way so it is completely underneath the mani for a while before it comes out to the driver's side to the back
I also have mine running under the intake there SHOULD be enough pressure to feed oil to the turbo just make sure the feed hold on the turbo is as vertical as possible and the return is straightdown.
no mine is under the intake mani, it couldnt go under the ex. mani since the turbo is offset from it. kinda hard to explain but from the way I read his post I think he meant the intake.
BLKCRX
Dec 20, 2002 05:41 AM
