Oil line question
Old Feb 4, 2002 | 05:40 PM
GruvyTune's Avatar
New User
Default Oil line question
Hey.
When you guys installed your feed lines, how did you get all your metal shavings out?
When you went to prime the line by cranking the engine, how fast did the oil come through?
Mine goes really slow. My first turbo burned out and was rebuilt. I finally hooked my oil pressure gauge right to where the turbo oil feed is and I get like no pressure. The line gets real hot though when the car is running and I assume there is flow. I wonder now.
I have a mechanical testing unit on order and should be here tomorrow to test everything. I'll just poo poo if I have no pressure there for real! I don't want to have to take that oil feed line out again from the back of the block.
thanks.
torin
Old Feb 4, 2002 | 05:43 PM
ElectronVTEC's Avatar
Default Re: Oil line question (GruvyTune)
Mine crept out pretty slowly too. We filled up part of a water bottle with oil from the line to try to get anything out of the line. I've let it run for quite awhile now and always cooldown after a drive, so far no smoke... here's to hoping! EV.
dustin's Avatar
When you crank the motor... the oil will pump through the line a bit and then when you stop cranking it will flow back.... so it's hard to get it to flow. You almost have to aim it directly towards the ground to get any sort of oil out of that thing..
Dustin
Old Feb 4, 2002 | 05:46 PM
D-SPEED's Avatar
Default Re: Oil line question (dustin)
what metal shavings are you talking about ? from cutting the lines to size ?
[Modified by D-SPEED, 6:46 PM 2/4/2002]
Old Feb 4, 2002 | 06:25 PM
GruvyTune's Avatar
New User
Default Re: Oil line question (D-SPEED)
I tapped the block to install my T fitting.
Old Feb 4, 2002 | 06:28 PM
GruvyTune's Avatar
New User
is it reasonable to start the engine and let it flow through to test it since the turbo is not spinning really at idle?
Old Feb 4, 2002 | 06:39 PM
Etylorcen's Avatar
Are you talking about metal shaving from the oil return line?
Old Feb 4, 2002 | 07:29 PM
GruvyTune's Avatar
New User
Default Re: Oil line question (Etylorcen)
no, feed.
Old Feb 4, 2002 | 07:30 PM
TurboSedan's Avatar
New User
I assume they are talking about the feed line.
Old Feb 5, 2002 | 09:13 AM
grnsol's Avatar
New User
Just a thought, but wouldn't it be easier to run oil through the line before installing it on the block???
Old Feb 5, 2002 | 10:01 AM
blowncivichb's Avatar
Default Re: Oil line question (grnsol)
Are you guys blind!!!
He clearly stated twice that he tapped the BLOCK. When you tap the block it causes metal shavings from the threads to remain in the thread hole. He's trying to flupoo poo out by running oil through the feed line into a container.
Sorry, but please read before posting.
Old Feb 5, 2002 | 10:03 AM
D-SPEED's Avatar
Default Re: Oil line question (blowncivichb)
gruvytune- where did you tap the block ?
Old Feb 5, 2002 | 10:21 AM
GruvyTune's Avatar
New User
I tapped it where most people do.. in the location where the stock sensor is. So I have this..
BLOCK--->T---Stock Sender
-3AN oil feed---------------------------->T------Greddy sending unit
-3AN line to turbo inlet
torin
Old Feb 5, 2002 | 10:54 AM
TurbodCX's Avatar
poo poo poo poo poo poo poo poos poo poo, i just wnated to see if it would turn poo poo* in to the poo poo word
later
Old Feb 5, 2002 | 01:46 PM
89civic1.8T's Avatar
Default Re: Oil line question (TurbodCX)
I disabled my ignition and cranked the enigine till oil came out of my turbo. It took a good 30 seconds before I got anything out of it.
memorybox
Dec 6, 2006 03:14 PM
SiR99
Jun 11, 2006 09:09 PM
SuzukaBlueAP2
Jul 7, 2003 02:36 PM
MikeMAN
Jul 2, 2002 09:25 PM
turbotec
Feb 26, 2002 12:36 PM
