TurboXS Boost Controllers
I was on Lightning Motorsports website looking at the TurboXS boost controllers and there is a standard boost controller and a high performance one. On the high performance one it states that it's a ball spring design and gets you to full boost sooner than stock. I thought the only difference between the two was the ability to go higher in boost on the high performance one, but under the description for the standard one it doesn't say it's a ball/spring design or that it gets to full boost quicker. Is it the same design with just a more powerful spring and housing for the high performance one or is it a different setup that is better that I should get even though I only want to increase the boost to 7psi, 12psi If the motor goes and I rebuild. Confusing? Thanks
The boost controller difference is one is bleeder valve the std one an the high performance is ball and spring design which acutally very nice if you need one let me know.
Hmmmm ...... Let me know prices on both and more info from Std vs. Ball if you could please.
E-mail: vrflyer@columbus.rr.com
the side *** is your fine adjustment use a allen key to adjust the top is your wide range. Try to adjust the fine adjustment to help spool an the top to increase or decrese the major bosot levels.
jetlude
Aug 1, 2007 09:13 AM
