Turbo XS HBPC boost controller help.
Old Aug 10, 2004 | 07:32 PM
Sketch_hs's Avatar
Default Turbo XS HBPC boost controller help.
well i got this for free but there are two adjustments one on the head, one on the brass part on the side.I have no manual.... anyone know how to work this thing or can point me to a guide? thanks.
"High Performance Boost Controller - Adjustable ball/spring design gets you to full boost hundreds of RPM faster than stock!
Designed for those who want the ability to radically increase their boost levels 1 to 30 psi above stock, but don’t want to pay hundreds of dollars to do it. The TurboXS High Performance Boost Controller (HPBC) is the right choice for simple, accurate and reliable high level boost control. The HPBC has two (2) boost control mechanisms built into it. One is a ball and spring mechanism for large and coarse boost pressure increases and the other is a bleed valve system for precise boost pressure setting. The ball and spring mechanism keeps pressure out of the wastegate until the preset boost level is reached, significantly reducing wastegate creep and providing quicker turbo spool up. Boost is adjusted with the simple turn of the screws using the included 2mm hex key.Kit Includes: High Performance Boost Controller, 6mm vacuum / pressure hose, Mounting Bracket, 12mm hose clamps, 2mm Hex Key. Installs as easily as our Standard Boost Controller: Simply cut the waste gate pressure hose and insert the supply pressure hose onto the brass nipple of the boost controller. Insert the waste gate supply hose onto the blue colored nipple. Secure the hoses with hose clamps. The Boost Controller can be mounted with included mounting bracket."
Thanks.
Old Aug 10, 2004 | 08:17 PM
Nikoli's Avatar
Default Re: Turbo XS HBPC boost controller help. (Sketch_hs)
all you need to know http://www.turboxs.com/HPBCinstallation.htm
Old Aug 10, 2004 | 08:43 PM
Sketch_hs's Avatar
Default Re: Turbo XS HBPC boost controller help. (Deckedlude)
OMG THANKS!
Old Aug 10, 2004 | 08:53 PM
Nikoli's Avatar
OMGHI2U!!!
google always amazes me too!
:: i think you should hook me up with some defi's at cost for that ::
Old Aug 10, 2004 | 09:06 PM
Sketch_hs's Avatar
i'll do my best to get you a GREAT price. infact i'll do it for anyone, just call my shop!
we'll beat anyones price... or at least try to
rickturboteg
Aug 28, 2006 05:36 PM
GettaluvR
Nov 2, 2002 10:38 AM
echo999
Oct 3, 2002 07:41 PM
accordfreak
Dec 25, 2001 12:20 AM
SIK IN DA HED
Sep 13, 2001 03:16 AM
