Will this fuel combo work?
instead of using stock injectors, intank pump and FMU i was thinking of using
450cc DSM injectors and VAFC hack
would i still need the intank pump?
no, you would not. The purpose of getting the bigger pumps is to supply enough fuel at higher fuel pressures, which without a FMU you, you won't see ultra high fuel pressures. The stock pump is sufficient
i dont have a wideband
but was gonna just not run above 5-7 PSI till i get it tunned and hope that the autometer a/f gauge stays green a WOT
search around and find a dyno center in your area. http://www.dynojet.com is a great place to look. Many dyno centers have wide band o2's. A good safe setting is -37% all the way across. Definately be easy on it before you get it tuned though
only one near me is
D R T Inc.
50-33 73rd Place
Woodside, 11377
Tel. 718-397-8586
and they aren't too cheap
as long as i know that the 450's and VAFC hack will work with nothing else i'm happy
D R T Inc.
50-33 73rd Place
Woodside, 11377
Tel. 718-397-8586
