lack of vtec when hot?
Old Dec 2, 2002 | 01:45 PM
andrewasf77's Avatar
Default lack of vtec when hot?
my type r has been running a little hot lately (the temp is above the half way point) and it seems that when i get into an open road and push the car the vtec does not kick in. anyone else have this problem, or have any idea whats going on? thanks
Old Dec 2, 2002 | 06:35 PM
CIVILGSR's Avatar
Default Re: lack of vtec when hot? (andrewasf77)
how far is the temp up past the half way point? also does the vtec open up and make noise but not pull or does it just do nothing and make no noise? i am having the same problem my vtec on fully built gsr makes a hell lot of power and makes no power on the dyno in vtec.
Old Dec 2, 2002 | 06:49 PM
sleeprhatch's Avatar
change your oil, it may be getting to thin with the heat. not building enough pressure....maybe
Old Dec 2, 2002 | 06:50 PM
Default Re: lack of vtec when hot? (CIVILGSR)
it was pretty close to the red over heating mark
Old Dec 2, 2002 | 07:11 PM
94TealGSR's Avatar
Default Re: lack of vtec when hot? (sleeprhatch)
What he said.. but if you're almost overheating you have more important problems!
Old Dec 2, 2002 | 10:36 PM
Default Re: lack of vtec when hot? (94TealGSR)
thanks, thats obvious, but i was wondering if the functionality of the vtec is affected, since vtec works on speed, oil pressure, and vehicle temp.
Old Dec 3, 2002 | 09:43 AM
spooled b16's Avatar
how bout that coolant some times it's the real obvious things. with it running that hot do you have any type of smoke, but with such a high comp. beast it is probally just the oil getting thin like what they said
Old Dec 3, 2002 | 01:30 PM
Default Re: lack of vtec when hot? (spooled b16)
nah, there is no smoke coming from the engine. it only does it after the car is running for a while and really starts to heat up. in the morning or at night it runs like it should.
Chpwhtek
Mar 19, 2012 04:48 PM
92 bandit
Aug 24, 2006 09:04 AM
acmeotally
Jul 28, 2005 02:26 PM
lmiguelvv
Oct 19, 2004 06:55 PM
98cwtypeR
Dec 4, 2002 04:26 AM
