Balancing that important?
Old Nov 30, 2002 | 11:52 PM
KS-R's Avatar
Default Balancing that important?
How important is it to balance a bottom end? Is it really that crucial? Does it really make that big of a difference? I'm thinking of stripping my H22 motor apart and doing a complete balance of the whole rotating assembly. What else should I do while I'm at it? Don't think I'll be replacing any of the pistons with forged ones, etc.. or anything like that.. Probably just stock components. Any ideas?
Old Dec 1, 2002 | 12:01 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Balancing that important? (KS-R)
like any upgrades on an engine, balancing is good in many aspects. it keeps the rotational assembly from spinning itself apart (well better than the nonbalanced one). it will allow the engine to rev higher (but not too high, without upgrading the valvetrain). it will make for a smoother, quieter running engine. if you can afford it (and it should not be too expencive), do it.
make sure they balance the clutch as well.
stan
Old Dec 1, 2002 | 04:08 AM
CRXGSR's Avatar
What happened to those Wiseco pistons that you had on the shelf? Not for your H22A application?
Old Dec 1, 2002 | 07:20 AM
earl's Avatar
Default Re: Balancing that important? (CRXGSR)
Just balance crank only, no need to do pistons etc. Also micropolish crank and you are good to go
Old Dec 1, 2002 | 10:11 AM
boomslang's Avatar
Have the crank, crank pulley, flywheel, and pressure plate all balanced. Any good shop will balance them independant of one another.
You will need to have the crank micropolished after the balancing.
Most of the aftermarket pistons and rods out there will be balanced pretty well, but it won't hurt to have them checked.
Old Dec 1, 2002 | 05:26 PM
KS-R's Avatar
Default Re: Balancing that important? (boomslang)
Just wondering if there would be any noticeable gains from this? I'm assuming longevity, but what about power wise? I assume the motor will run more smoothly and quietly.
CRXGSR... It's still sitting on the shelf.. Patiently waiting.
Cyber ITR
Jan 19, 2004 03:14 PM
KS-R
Dec 1, 2002 11:16 AM
DLB1994
Jun 11, 2002 06:35 AM
DLB1994
Jun 10, 2002 10:17 PM
BLKCRX
Jun 10, 2002 03:27 PM
