?balancing?
Old Jun 10, 2002 | 07:57 PM
DLB1994's Avatar
Default ?balancing?
putting new forged pistons in will it hurt performance with out balancing it with the crank i know it will gain performance with balancing but will hurt it
it should still run like it did with the stock pistons
Old Jun 11, 2002 | 06:16 AM
DLB1994's Avatar
Default Re: ?balancing? (DLB1994)
Old Jun 11, 2002 | 06:35 AM
X2BOARD's Avatar
Your post sounded confused, but I guess you are asking this... Balancing=better performance ?
No, it won't give any power/performance. Balancing will allow the engine to rev smoother and increase it's longjevity. Forged pistons and rods... and even the honda crank, is pretty well balanced stock... not a high speed balance, but very close in weights (this is typical and does not mean every piston set is perfect). You can put in forged pistons w/o balancing... but why ? it's not that expensive to do and will allow the motor to live longer under high revs.
michaelprice83
Feb 16, 2011 05:56 PM
mcgee*
26
Jan 23, 2007 04:43 PM
DLB1994
Jun 11, 2002 10:29 AM
DLB1994
Jun 10, 2002 10:17 PM
