I summon all boost freaks.....
Old Nov 26, 2002 | 03:17 PM
armharm's Avatar
Default I summon all boost freaks.....
ok you guys.. i finally made up my mind...
i was planning on getting a full WW RS lip skirt kit, white paint job, c/f hood, jdm headlights, and rims... all of which were gonna cost me approximately $2500-$3000. i decided **** looks.. i'd rather go with power.. (this decision was followed by my realization that my car is slow)
now i need ur help.. i cant follow in the official turbo thread so i started this one... what exactly will i need to boost my h23a1 with no more than 6-7 psi and maybe more later? i have a completely stock engine, not built or anything... i have currently 115k miles on it and it is in PERFECT condition, previous owner babied car (was first owner). please gimme a listing of what i'll need exactly (i.e: actual turbo, fmic, manifold, bov, EVERYTHING) and how much each will cost approximately... gude i kno u can answer all these questions off the top of ur head so i'm counting on u and a few other boost freaks in here... i am very determined to be boosted by february...
TIA guys and dont post stupid msgs saying "use the search button" because it doesnt ever answer my entire question.. thanks again..
Old Nov 26, 2002 | 05:34 PM
cd7's Avatar
cd7
Default Re: I summon all boost freaks..... (armharm)
I have a turbo kit perfect for you and it was in my h23a1 too. it is complete
here is what i have.... t3/t4 turbo (turbonetics), deltagate wastegate, greddy bov, apexi intercooler with all piping in silver, custom manifold with downpipe and greddy mid-pipe, lots of gauges:fuel,exhaust,big boost,a/f,oil all are autometer gauges, nology hot wires, fuel pump, turbo filter, hks turbo timer, blitz boost controller, rc 550 injectors. i think that all............... make me offer
Old Nov 26, 2002 | 05:40 PM
armharm's Avatar
Default Re: I summon all boost freaks..... (enVusACCORD)
u got pm..
BoostedH23a1's Avatar
well here we go..
-Rev hard manifold -475
-Rev Hard downpipe- 90 (piece of ****, just cause it doenst bend around oil pan)
-turbo- (you have options here but i reccomend t3/t4b for low boost t3/t4e for high boost) anywhere from 500-750ish..
-Wastegate-- tial recommend 220ish or deltagate 150ish
-Frount mount intercooler-spearco recommend -300-700 depending
-intercooler piping-- custom or get drag or fmax--300-700 depending on where u get it
-oil feed line- braided stainless--65ish
-oil return line-5 dollars
-pipe to braze into your oil pan (or u can get a braided stainless oil return kit for 99 dolars i reccomend this..
-Blow off valve--200ish
-check valves u can get shitty fish tank ones or missing link-get missing link for 70
-couplers and clamps-50ish
-angle couplers- no clue probably bout 30ish
-turbo gasket-8ish
-new exhaust mani gasket-20ish
-antisieze-4ish
-NGk BRK7E spark plugs-5.12
-I reccomend an igntion also.. if your not going with standalone get msd with Boost timing retard.--300ish
-good spark plug wire-80ish
i reccomend u wait till the gen 4 drag kit is out. its out know but good luck getting it.. gen 2 kit for 4gen sucked (manifold i mean)
i would just get a full kit if i were u
Old Nov 26, 2002 | 05:45 PM
armharm's Avatar
Default Re: I summon all boost freaks..... (BoostedH23a1)
damn thanks boosted... i appreciate it.. yea sounds like a complete kit is good for me.. how much longer till the drag gen 4 becomes readily available?
Old Nov 26, 2002 | 07:38 PM
Boostless97Lude
Guest
Posts: n/a
the DRAG gen 4 for the H22 is out, so i would think that for the H23 shoudln't be too long, but, go with F-Max, DRAG stuff is garbage, IMO, one of my friends had a DRAG on his B16 swapped Civic, and some of the stuff was just plain garbage, like the downpipe, they don't even attempt to make a model specific one, i mean, this things don't even come close to fitting, and the missing link and FMU... WTF is that, F-Max come with a MF2, which is a piggyback system to control your fuel, only downside with that though is you have to add 2 additional injectors into the charge pipe just before the TB... to be honest, i would have gone with the F-Max kit myself over the GReddy, except for the fact that with my hood, i like the internal wastegate idea a lot better
Old Nov 26, 2002 | 07:53 PM
armharm's Avatar
Default Re: I summon all boost freaks..... (Boosted97Lude)
cool... thanks i'll look into fmax too...
Old Nov 26, 2002 | 07:55 PM
Boostless97Lude
Guest
Posts: n/a
it's about time
Old Nov 26, 2002 | 08:11 PM
LordVtec's Avatar
I am still hoping santa will help me complete my kit... lol.. need boost for the new year.. lol.. anyhow, he Armo guess your looking for some more "bolt ons" huh? heh heh heh (that post is still haunting you to this day) j/k
Old Nov 26, 2002 | 11:37 PM
PrecisionH23a's Avatar
yo man im drunk sas **** right now, ill asnwer your question int he am. peace!
Old Nov 27, 2002 | 12:57 PM
armharm's Avatar
Default Re: I summon all boost freaks..... (GudeH23a)
LMAO
Old Nov 28, 2002 | 08:06 AM
rjr162's Avatar
The F-Max setup is pretty nice, only downside is the extra two injectors are in the intake duct, and if you push the boost too high it's possible the extra fuel won't enter all cylinders evenly, causing a lean situation in one or more and BOOM. We're currently running the kit @ 9 psi now and it's holding fine.. daily driven on stock internals for over 15,000+ now. But either way, any of the setups above would work good, but I'd also throw a B&M oil cooler into the mix. This will help out a lot, and you won't have to set your turbo timer to such a high time since the oil will already be cooling while you run. oh, and don't forget your guages! heh. Oil temp, boost, and A/F (maybe oil press if you want).. but it will help you out when you first get stuff going to monitor your setup to make sure you're not going overboard with the boost. Lastely, pay the $80 to get it dyno tuned!!! This is a MUST. if you don't, things will start to go wrong. Take it to a shop that's experienced with this stuff (Such as Kauffmann Motorsports if you're near Harrisburgh, PA, which is in southeast PA).
Old Nov 28, 2002 | 02:39 PM
armharm's Avatar
Default Re: I summon all boost freaks..... (rjr162)
thanks... i'll do that.... although i doubt i'll drive to pennsylvania i'll find one here in cali...thanks again..
Old Nov 28, 2002 | 06:03 PM
Default asdf
fmax is overpriced.
new gen 4 will be like fmax pretty much. little different piping design.
Old Nov 29, 2002 | 01:26 AM
armharm's Avatar
Default Re: asdf (BoostedH23a1)
fmax is overpriced.
when do you think it'll be readily available?
DntFk_jdm
Nov 2, 2015 03:19 PM
1sic3dr
Aug 11, 2007 03:28 PM
slows2k
Feb 28, 2006 02:13 AM
Evo-man@20psi
Mar 10, 2005 03:44 AM
Racer X
Oct 16, 2002 08:59 PM
