can someone please help me with my revhard kit problem
my fuel pressure is at 50PSI at idle
i tried fixing the problem by putting the stock fuel pump back on replacing the FPR and disconnecting the FMU
still the car idles at 50PSI
last night my injector seals exploded and cause a real bad leak of fuel
here is the link where some people tried to help
http://forums.clubsi.com/showflat.ph...sb=5&o=0&fpart=
This might not be a kit problem if you tried putting all the stock fp or pump back on and still exist. Did you try going to a mechanic and install their own fuel pressure meter or gauge. YOu sure the inlet(sideport) and outlet(bottom portt) is correctly connected. Have you tried disconnecting the FMU completely? Check for a clogged return line. Good Luck!
all lines were replaced put back to stock(removed FMU, and intank pump) and we replaced the gauge with my mechanics gauge who happens to be my dad, and still we have 50PSI in the fuel rail
we found out why i am smoking so much, the turbo has blown seals. i pull of the piping that comes from the compressor to the intercooler and there is alot of oil in there.
k2civic
Dec 26, 2003 07:42 PM
uneekcrx
Apr 26, 2002 07:52 PM
