EG Civic B16A Hunting IDLE and jerking. HELP PLEASE
Old Apr 11, 2023 | 03:01 PM
SLAMERON's Avatar
Default EG Civic B16A Hunting IDLE and jerking. HELP PLEASE
So recently i changed out my IACV Hose that connects to the throttle bottle cuz it was old and short so it would mess with my idle. after i replaced it, it still does the weird hunting idle when i come to a stop it would almost shut off and come back up but it has shut off before. this is on a cold engine BTW when its full warmed up for like 20-30 min it stops doing it when i slow to a stop but on the way home i went over a speed bump lil hard and it did it again and the jerking when i accelerate stops also( when i keep a constant speed i feel it cut out maybe idk) . Ive been told theres a bubble in the coolant that would cause this which i havnt bled it yet but if theres any other problem it could be please lmk cuz this **** is actually annoying. ( btw im new to cars n stuff ).
Old Apr 11, 2023 | 03:11 PM
Chance EG's Avatar
Default Re: EG Civic B16A Hunting IDLE and jerking. HELP PLEASE
Been awhile since I've looked at an OEM intake setup, but isn't the IACV supposed to plug into the intake manifold, not the throttle body? If it is on the throttle body, it would at least have to be after the throttle blade.
Bleeding any air that may be in the cooling system is a good idea. If the problem comes and goes, even when the car is warm, that could be part of the issue. Otherwise, "clean the IACV filter" is something you'll hear often, if you didn't do that when you replaced the hose or don't know when the last time is your IACV has been serviced it'd be worth looking at.
Make sure your idle has been properly set:
FITV could also cause issues on cold start but I'm a bit less familiar with that part, and I think one of the above things is more likely the cause.
Old Apr 11, 2023 | 03:20 PM
SLAMERON's Avatar
yea i sprayed sum cleaner in the IACV but the hose connects to the throttle body i think it helps keep it like warm during the cold so it doesnt freeze or sumthing. but ill try to bleed see if that works if not ill come back. and I dont have a OEM intake its a aftermarket 1 its a Skunk pro series with the Skunk throttle body
Old Apr 11, 2023 | 03:41 PM
Chance EG's Avatar
Ah ok, yes sorry I'm biased towards my own intake I recently set up which is set up a bit differently. You're right, a vacuum line from the TB to the IACV.
There's two videos on YT both from good technicians, I'd watch both of these:
Old Apr 11, 2023 | 03:44 PM
SLAMERON's Avatar
KK ill watch these thanks. ill LYK if i fix the problem
Old Apr 11, 2023 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
For Heaven's sake gang... those hoses have COOLANT running through them... NOT air !!! If a "hunting" or high idle comes and goes... it is likely a coolant bubble and will need to be bled out. If it is consistent, you will have to consider other issues. Remember that while the engine is warmed up and idling, you can place a finger over the holes in the front opening of the throttle body to isolate two potential trouble spots: The IACV and the FITV. If you cover the 10 O'clock hole and the idle comes down to normal or the hunting stops... then the IACV is the problem. If you cover the 8 O'clock hole and the idle comes down to normal or the hunting stops... then the FITV is your problem.
Old Apr 11, 2023 | 10:46 PM
SLAMERON's Avatar
im going to bleed the system TMRW if that doesnt work ill try the hole thing but what HOLE are u talking about exactly if u got like a visual u could show. idk to much about cars just got into it.
Old Apr 12, 2023 | 12:29 PM
spAdam's Avatar
Loved
Community Favorite
Check your TPS calibration. Make sure it is not moving around due to the tps and/or its connector being loose.
The jerking tells me that the low end may be set too low... so when you are creeping along at very light throttle, the ecu keeps going in and out of idle control thinking that you are off throttle.
Old Apr 12, 2023 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Try the hole thing first... it is EASIER !!! LOL
Remove the air intake tube from the throttle body and you will see the holes at the 8 and 10 O'clock positions inside the throttle body. You do know how to read a clock, right ? If you need a photo, it will likely be Sunday before I have time to post one.
Old Apr 13, 2023 | 12:39 PM
SLAMERON's Avatar
kk ill try the hole thing i already bled the coolant and i feel like it got worse with the idle for sum reason. i took a vid when i went to go test drive a day later and its just weird. https://streamable.com/w8lt7m thats the link to the video
File Type: mov
Old Apr 13, 2023 | 12:41 PM
SLAMERON's Avatar
if im thinking of the right plug the TPS is pretty tight it aint moving at all the connector ill check for sure but heres a video of just trying to idle
File Type: mov
Old Apr 14, 2023 | 04:38 PM
SLAMERON's Avatar
Hey Took off my tube i found this hole,
and it was pretty dirty behind the gold plate thing i bought sum cleaner if that would also cause sumthing to **** up my car.
Old Apr 14, 2023 | 05:18 PM
SLAMERON's Avatar
yea bro i dont think my car has a FIVT or whar ever its called i cleaned the throttle body tho
Old Apr 26, 2023 | 12:03 PM
SLAMERON's Avatar
I seem to fix the problem. i cleaned the Throttle Body and i reset the ECU and its been idling fine with no dropping down and turning off so there that.
Old Apr 26, 2023 | 01:22 PM
SLAMERON's Avatar
Nevermind I lied its still doing it. I didnt let it warm up all the way cuz it was hot asf out i started to drive it seemed fine until it started to slowly go down and almost shut off but the good news is that after driving and letting it warmup after it stopped doing it so that tells me it has sumthing to do with the coolant maybe. going to bleed that again and hopefully it fixes it.
jayeghatch
Aug 28, 2012 03:59 PM
b16a4
22
Jun 1, 2007 02:37 AM
acidx
Jun 5, 2004 02:15 PM
ITR1071
May 25, 2002 01:05 PM
