94 eg b16a problem w/ idle
so i did a swap into my 94 eg with a b16a, so i had a smooth idle after the swap but then i had to remove the heater core hoses to replace the T bracket cause the one i had didnt align properly. an after that i got a bad idle.
i bleed the coolant system a few times an it doesnt want to get better, so i clean the IACV with cleaner an try it again an it still has an idle that goes up an down.
what else can i do or check.
i check the voltage on the iacv plug ani got a 12.34,an when the car was on i unplug it to see what it did an the car died.
any help with really help me out thanks
Re: 94 eg b16a problem w/ idle
so i check for a vacuum leaks an didnt find any.
but the weird thing is that i disconnected the Tps sensor an the car idle smooth now.
so it running with no tps or map sensor cause i dont have a tb with both sensor for the b16a.
ITR1071
05-25-2002 01:05 PM
