B18c5 overheating
Old Jul 18, 2018 | 08:12 PM
Egsirvtec's Avatar
Default B18c5 overheating
Hello everybody. I am new to this forum and would like to know if anybody has an idea of why my b series is overheating. It’s a 98 spec type r on a 93 civic hatch. Fan works, but looks like it gets low on coolant. I notice temp raising up when stuck in traffic on a 90+ weather. Like I said, fan works but temp goes up really fast if I don’t keep car driving. Any help will be appreciated.
Old Jul 18, 2018 | 09:15 PM
tony_2018's Avatar
Fish Twig
Default Re: B18c5 overheating
low on coolant, what does that tell you?
Old Jul 19, 2018 | 05:39 AM
Egsirvtec's Avatar
a leak somewhere? But I don’t see any coolant on the floor at all. I Checked all the hoses and they seem ok. I don’t see a leak anywhere. There is a coolant smell coming from the engine bay tho...
Old Jul 19, 2018 | 06:04 AM
LSEJ's Avatar
Possible that the heater core is leaking. Any coolant on the pass side floor?
Old Jul 19, 2018 | 06:14 AM
2x0's Avatar
2x0
10 Year Member
Small coolant leaks can be hard to find since it dries up, but how fast are you losing coolant?
What fan and thermostat are you using? What coolant mix? What radiator?
Old Jul 19, 2018 | 09:27 AM
Egsirvtec's Avatar
I will have to check the passenger side for leaks. I am using regular autozone thermostats and aluminum radiator? It does not get very low. Temp went higher when stuck in traffic? Can it be maybe a leak form radiator cap?
Old Jul 19, 2018 | 10:22 AM
Db1_77's Avatar
My guess would be a radiator cap unable to maintain pressure.
Old Jul 19, 2018 | 10:56 AM
tony_2018's Avatar
Fish Twig
you just bought this thing? you just did a swap? you stole it recently?
Old Jul 19, 2018 | 11:10 AM
Egsirvtec's Avatar
I will try changing the radiator cap and thermostate. Will keep u updated. Thank you
Old Jul 19, 2018 | 01:10 PM
Egsirvtec's Avatar
Forgot to ask, if aftermarket aluminum radiator cap needs replace, where do I find one? Does OEM fit?
Thank you
Old Jul 19, 2018 | 02:59 PM
Freedo_Civegra's Avatar
Thank you
Bring the cap to a parts house and match it up with one they have. Write that number down in a notebook and keep it in your glovebox.
Old Jul 23, 2018 | 09:13 PM
Egsirvtec's Avatar
After doing a pressure test on radiator, I found a small leak on radiator. That explains why the smell of coolant but no coolant was visible as it evaporating really quick due to aluminum radiator being hot. I will replace radiator and hopefully that will fix it
eman96
Jul 29, 2014 06:53 PM
turboman2.2
Aug 1, 2011 03:55 AM
mrx
Jul 4, 2006 07:44 AM
zoolander
11
Feb 14, 2006 07:38 AM
dkdjlf
Aug 14, 2003 10:34 AM
