Transmission needs some pumps in the clutch to switch gears smoothly
Old Jun 24, 2018 | 09:36 AM
fgb000's Avatar
Default Transmission needs some pumps in the clutch to switch gears smoothly
Hello,
My manual gearbox needs footsteps on the clutch pedal so I can change gears smoothly without scratching or grinding.
If I go straight from one gear to another It scratches the gearbox, and the gear's teeth. I cannot just step down the pedal once and go from onde gear to another freely and smoothly.
Then, in order to switch gear's smoothly I have to take my foot up totally off the clutch pedal and step it down all over again, so that the exchange gear can sync smoothly again.
What I feel is that if I try to switch gears without having my foot up all off the clutch pedal and stepped it down all over to the bottom again, there won't enough oil or oil pressure in the trasmission so the gears can fit without grinding and scratching It to sync in smoothly.
What should I do?
Civic 98 ex manual. Transmission S40
Thank you
Old Jun 24, 2018 | 09:59 AM
Wonabe's Avatar
Default Re: Transmission needs some pumps in the clutch to switch gears smoothly
Change the clutch master and slave cylinders. Not one or the other, go ahead and do both at the same time.
Old Jun 25, 2018 | 02:14 PM
fgb000's Avatar
Ok. Im having a hard time trying to find a brand new and good quality cilynder, for both Master and slave. The only Brand that seems to be less worst is the Exedy one. But even this one is not a good quality compared to an OEM option, a japanese one.
Could the Master and ir slave cilynder be repaired with this kit:
https://produto.mercadolivre.com.br/...e-1516-pol-_JM
They sell It according to inches size.
there is 7/8, 15/16, 3/4...
How can i tell How many inches are mine cilynders?
1998 ej8 sedan
Thanks.
Old Jul 4, 2018 | 06:39 PM
fgb000's Avatar
Pretty please
Old Jul 4, 2018 | 07:55 PM
crazyhorse2011's Avatar
10 Year Member
Loved
i put in a parts store brand one in my civic when it blew. took a couple hours to do both cylinders and bleed the system. drove it for 10,000 miles with no issues and sold the car with it working. i wouldn't worry about going top shelf on these
Old Jul 4, 2018 | 11:03 PM
tony_2018's Avatar
Fish Twig
Go buy oem
Old Jul 4, 2018 | 11:09 PM
10 Year Member
Loved
Originally Posted by tony_2018
Go buy oem
on a 25 year old clapped out bucket? Why?
Old Jul 6, 2018 | 08:00 AM
NVturbo's Avatar
O.G. triple O.G.
you should ask yourself that same question with your ghetto rigged rides
Old Jul 6, 2018 | 09:07 PM
fgb000's Avatar
Hi, How many bottles of Honda dot3 3 Will O need to fill up the system, after overhaul, changing both cylinders?
The bottle of dot3 sold on Honda dealers next to me here holds 0,374068 us quarts, that is 354 mililiters.
How many bottles Will I need?
Thanks.
Old Jul 6, 2018 | 09:11 PM
10 Year Member
Loved
Thanks.
just get a couple bottles. Cant be that expensive. If you have 2nd grade math skills you should easily be able to figure out how many bottles are necessary. Then again, judging by your typing skills....
anyway, just get 2x what is necessary, youll have to waste some out flushing the system anyway
Old Jul 7, 2018 | 06:17 AM
fgb000's Avatar
Does anybody have a better or more precise answer please?
Old Jul 7, 2018 | 08:07 AM
10 Year Member
Loved
look bud its not rocket science. A half gallin of dot 3 is what, like 10 bucks? Get one of those and be done with it. More than enough for ten clutch hydraulic replacements right there
Old Jul 7, 2018 | 05:44 PM
Jesse Lamp Jr.'s Avatar
Icon6 Re: Transmission needs some pumps in the clutch to switch gears smoothly
Look having some DOT3 brake fluid laying around isnt a bad idea. You never know when you are going to need it again. You could fix this problem and have your wheel cylinders give out next week. Just get what the man says or get a little bit and have to walk yourself to the store to get more when you didnt get enough
Old Jul 8, 2018 | 06:11 PM
civic402lx's Avatar
https://www.exedyusa.com/products/sp...acement-parts/
plug in your car info.. exedy orm made master and slave.
buy both master and slave for less then 40shipped
go to honda dealer buy 2 bottles of dot 3. Extra bottle is there just in case. Spare is good to have.
you will end up using up to 1/2 a bottle for the bleeding process.
dont make it harder then it is.
suction out old fluid from reservoir or
drain fluid at slave bleed nipple
remove old master and slave
line up old master and new, make sure they are the same length
install
bleed
Old Jul 8, 2018 | 10:24 PM
fgb000's Avatar
Thank you very much!
Just a question, shouldn' I bleed the system before installing the new cylinders?
Thanks.
Old Jul 9, 2018 | 05:30 AM
civic402lx's Avatar
No. Bleed it all at one time.
Old Jul 9, 2018 | 09:20 AM
fgb000's Avatar
I will bleed/ change the hole dot3 fluid inside the clutch system, Thats why Im asking, If Its better to bleed it all before replacing both cylinders, in a way that the old fluid will not touch my brand new cylinders.
Old Jul 9, 2018 | 06:15 PM
civic402lx's Avatar
If you want to waste your time and fluid, then by all mean, do it your way. If that makes you feel better then proceed. I see no reason to do it beforehand.
once you drain the old fluid there will be nothing but air in the line. So why would you bleed new fluid first, then go back and drain again, then remove old parts, just then to bleed the system another time after new parts are in.
Old Jul 9, 2018 | 07:10 PM
fgb000's Avatar
Thanks for explaining this to me.
what should be the diameter of the hose hole for a perfect fit on the bleeding screw?
Old Jul 10, 2018 | 12:35 PM
demon6666699999's Avatar
Bleed It in to a container, as long as you don't release the pedal while the bleeder is open it doesn't matter. Plus like civic402lx said your wasting your time and money, replace the parts and bleed once. Your over thinking it. You Maybe need two small containers of brake fluid or one large and have extra which is good to have around.
Old Jul 10, 2018 | 12:46 PM
If your using a vacuum pump to bleed it. which i doubt you are. Don't pump it with the bleeder open. When you get a firm pedal, your done. No matter what method. You will replace the little fluid the system holds by bleeding it, If your already replacing both cylinders .After you bleed the system then you know you have new fluid which would cause them to fail. The only thing to worry about next would be a fluid leak from the lines through the rust or seals at both cylinders which you would see and you should be able to see already. Plus you would of already had a low fluid level which you haven't mentioned.
Old Aug 5, 2018 | 11:27 AM
fgb000's Avatar
Hi, I've changed both cylinders and bled the system spending 1 bottle of Honda dot3.
the DIY was rather an easy job to do.
The worst parts were the cotter pin removal from behind the pedal, and placing the slave cylinder inside the release fork's boot.
But after that everything went fine.
I've noticed already that my clutch is smoother of course, and the sqeaking sound dissapeared after i've bled it. Now I think that noise comes from air in the system when pushing pressure on It.
But after all it keeps grinding when I switch gears, the tranny is not smooth like butter.
It may have changed to a little bit more smoother but not how I was expecting It.
My old clutch master cylinder was leaking already with a lot of black "goo"coming out from the pin rod on the pedal, and now this issue is fixed at least.
But I keep feeling that there is not enough pressure pushing the release fork when I push down the clutch pedal, thats and why my "tranny's changing movement is so dificult and "grindy". On this matter the replacement of both cylinders changed It to a little bit more smoother.
Normaly to make the "switching gears movement on tranny" more smoother like butter I need to go back and forth trying to not "touch" the "grindings" along the tranny's path.
Like the manual tells me to do if I want to switch to reverse I should go to 5th first then come straigth down to the reverse gear.
Im not telling that I would allways need to do this kind of movement on the tranny to make the "path" clear and without grinding anything everytime I change gears. What Im trying to is to fix this and make this tranny relyable so i can think about something else when switching gears : /
I want to feel that like in my Civic '95 where vou can move the tranny from any gear to any gear freely , and It would feel like It the tranny is fixed on a "bucket of butter" down below.
There you can step down the clutch and "come with the tranny from the 5th to 1st without "grinding" or touching any "side walls" or anything along the path.
Its like if there the release fork is very well pushed down, giving me a "clear tranny's path movement". Free, fast, and smooth "stick on butter" movement I have on this '95 tranny when I switch gear. It allways go to a "right destination" without touch any iron stuff along the way.
Now on this '98 the "tranny's path" movement Its all grindy and very slow because im loosing power when I have to delay the movement trying to find a clear path on my tranny to switch gear without grinding.
I did calibrate the master cylinder Rod, by setting It to the same size of the old rod according to the size needed behind the clutch pedal.
I mean is there a fix or calibration for this? could It be the release fork that is too old already?
Thanks.
jv13193
Transmission & Drivetrain
Apr 1, 2014 08:23 PM
Johnny_9
Engine Management and Tuning
Nov 28, 2012 08:20 PM
battosai
Apr 25, 2008 02:51 PM
drSquish
Jan 17, 2007 12:22 PM
smooz EK
Oct 30, 2003 03:42 PM
