F22a1 Turbo Build
Old Mar 8, 2018 | 08:17 PM
David Busch's Avatar
Default F22a1 Turbo Build
Hi, I’ve been contemplating things I want to do with my 92 prelude S 2.2L sohc. And I’ve decided to keep the stock engine, upgrade internals, and add turbo kit on. I am on a tight budget. So this is going to take time to build up to what I want due to lack on funds to buy everything at once. Anyone have any suggestions on what I can do that would work best with Keeping the stock Sohc??
Old Mar 8, 2018 | 08:23 PM
TimiK's Avatar
10 Year Member
Default Re: F22a1 Turbo Build
never even consider budget builds
Old Mar 8, 2018 | 08:43 PM
what I meant by that was that I don’t just have 10k sitting around to buy the best of everything I want for this car. I want to do things slowly and build little by little.
Old Mar 8, 2018 | 10:44 PM
PreludeJunkie91's Avatar
Do just that then. Pick a power goal your satisfied with, Check if that goal is higher than what a stock block can take for boost because if your looking for big numbers your going to need a resleeve and figure out what parts will get you there. Budget builds are usually rush builds because you want it on the street fast and in a hurry to be with all the cool kids. Take your time man and start collecting parts.
Old Mar 9, 2018 | 09:46 AM
yeah, I have no rush at all. So that’s what I’d plan on doing. Just wanted to know like what kind of power a stock motor can handle. And then see what brands are good and what not. This is my first build. So I’m not too sure about that kind of stuff
Old Mar 9, 2018 | 01:08 PM
Aradin's Avatar
Premium Member
What a stock block can handle is going to vary wildly by a number of factors including quality of parts, condition of the engine, how the power is delivered, fuel used and tune, luck, etc etc. I would suggest keeping it under 300whp on a stock engine if you want any degree of reliability. You can push it beyond that to the 350whp range but you're going to be pushing your luck. The rods will go long before the pistons if the tune is good. If you end up breaking ringlands then your tune was garbage to begin with. I have been messing around with H/F series for over 12 years now and I have seen motors blow their guts out all over the highway at <250whp and some freaks that live forever at 400whp+. When in doubt, stay on the conservative side. A car constantly in the shop needing something is no fun at all.
Old Mar 9, 2018 | 05:07 PM
yeah that makes sense. My motor has 197K miles on it. But I do plan on upgrading all the internals before I boost it. Just not sure which brands are worth getting. I do kind of want to do little by little and keep it drivable throughout the process. I don’t want it to be sitting for months and months. So not sure in which order I should do things as well.
Old Mar 11, 2018 | 11:19 AM
Aradin's Avatar
Premium Member
Drive it and enjoy it now while you slowly buy quality parts. Get the chassis ready for boost before boosting it. Install better brakes, tires, check over and replace any worn suspension components, etc. These are things that can be done in a day and will have very little down time. Then when the time is right you can throw your new engine and turbo kit in, immediately head off to get a tune and you'll be good to go. More advice I can give you is race it at the track, not in the shop. Just take your time and focus on doing things the correct way and the end result will be much better even if it takes a little longer. As for what parts are worth getting, stay away from unbranded stuff you find on eBay. Do your research. There's a healthy forced induction section right here on this site with answers to a lot of questions you have or will have.
Old Mar 13, 2018 | 06:53 PM
thank you! That actually helps a lot!
Old Mar 13, 2018 | 09:23 PM
TimiK's Avatar
10 Year Member
Look into traction and cooling and try to find LSD transmission also
Snate
Dec 18, 2006 03:18 PM
1337D turboNiNja
Aug 5, 2004 03:50 PM
Serdar
Jul 5, 2004 07:27 AM
honda9369
Jun 11, 2004 07:19 PM
smoke3
Mar 9, 2004 08:11 PM
