Problem jumping ecu
Old Sep 26, 2017 | 08:40 PM
Smallpox13's Avatar
Icon2 Problem jumping ecu
So need some help, I'm trying to set the timing on my 1991 civic si. Engine is d16a6. So about a week ago I installed a new distributor and marked it's position. I take it to get it smogged and it fails bad. The tech tells me my timing is off. So I get under the service port so I can bypass it. When I connect a wire in there to bypass the engine the check engine light won't turn on. I tried a different wire to maybe get a better connection but still no luck. Am I forgetting a step?
Old Sep 27, 2017 | 05:44 AM
rice a roni's Avatar
Default Re: Problem jumping ecu
Does your check engine light work? Should come on for a few seconds when you key on.
Old Sep 27, 2017 | 06:11 AM
Smallpox13's Avatar
Yes when I turn the keys to on before I crank it the check engine light turns on.
Old Sep 28, 2017 | 10:50 AM
4drEF's Avatar
Keyboard Humorist
Jumping the connector essentially run a ground wire to B20 on your ECU.
It's possible that the ground wire isn't connected to your service connector so you can try hooking a ground to your paperclip.
If that doesn't work, then attach a ground directly at B20 on the ECU.
Old Sep 29, 2017 | 02:49 PM
jlicrx's Avatar
if you are OBD0, jumping the service connector to set the ignition timing will not turn on the Check Engine Light and you don't reset the ECU when finished
ej2 coupe
Nov 22, 2007 05:43 PM
Al-sonic
Jan 9, 2007 08:29 PM
soon2b
May 22, 2005 06:39 AM
95LSDOHC
May 5, 2004 09:43 PM
baonest1
Mar 18, 2003 09:48 AM
