Suggestions Request for a Newbie: 500+whp ls vtec possible?
looking for info in how to make this happen. I got a b18b1 block with GSR head.it will be going in a ek4 shell.I plan on rebuilding block getting head built tuned i need to be able to put 500+ to ground and what i mean ,by 500+to ground i mean 515,525 thype of 500+..
There are many threads like these, so you unlikely to get a detailed response here with such a generic question.
In short yes it is possible, the level of the build depends on what fuel you plan on running. A "pump gas" 93 octane 500whp build and an E85 500whp build are quite different. Decide on this first and then the other pieces will be easier to put together.
Also you need to decide what purpose you are building the car for - street, strip, dyno queen etc..
if you literally look on the same page that your posting on, you will see a thread that GEN2 is building a 500+ b series motor....
Don't worry ill do the work for you... https://honda-tech.com/forums/forced...build-3294903/
Depends on a tonne of variables that we don't know.
Compression ratio, turbo choice, manifold design, rev limit...
If one were so inclined, you could probably still build a pretty "responsive" turbo 500WHP Honda with the right choice in parts. A new 3071 could probably get the job done.
i plan to use supertec piston an rods set up gsr crank probably t3t4 on e85 tuned p&p the gsr head with dual valve springs skunk manifold stage 2 cames 1000cc injectors s trans
You want two tunes if going E85.-one as a lower boost pressure tune, and one to use higher pressure. use the boost controller to change settings when you change fuels.
Remember, "t3t4" is a very genetic term too use. That could literally be hundreds of wheel combinations, so you need to select a turbocharger that can reach you goal to match, and still be responsive in the lower boost pressures too.
The GT3071R can do up to about 450whp, but that's at higher boost pressures over 25psi. So, its close, but a teeny bit larger staying I the GT30 turbine wheel family will still be best.
E85 isn't the only high knock resistant fuel to use. It may be inexpensive to fill the tank, but more expensive to prep for. Just take that into account in your budgeting.
500whp on 93 octane requires a larger turbo to make that peak power number. After about 360whp -420whp is about as far as you want to go.
E85 isn't the only high knock resistant fuel to use. It may be inexpensive to fill the tank, butt more expensive to prep for. Just take that into account in your budgeting.
ARP headstuds - check
Stock ports are fine
Stock GSR cams are fine or you can upgrade to Skunk Tuner 1 or GSC T1
Valvesprings and retainers - check
1000cc injectors - too small for E85
DW 340 or Walboro 450 fuel pump
Turbo with a flow rating of at least 55 lb/min - GTX3071, GTX3076 (Gen 1 or Gen 2), BW S252 SX-E, BW S257 SX-E, BW EFR7163
VtecLsEater
19
Oct 8, 2008 02:00 PM
Demon_Dub
14
Feb 17, 2006 06:26 AM
