1998 Civic hoses?
Hello all. I need to figure out what kind of rubber hoses are used in two locations: automatic transmission cooling lines ;and the bottom of the brake fluid reservoir?
They appear to be the same size, and Autozone has told me that I can use any generic hose on both. Just wanting to double check because I see some online that are rated for fuel also..
Thanks!
Thanks!
This site provides very detailed information concerning fuel line rubber uses (quick google search):
Tech 101: Fuel-line hose – what you should and should not use | Hemmings Daily
Tech 101: Fuel-line hose – what you should and should not use Hemmings Daily
CALIdelsolSIR
11
Nov 27, 2005 07:25 PM
Seedc2
Jul 11, 2005 12:27 PM
