1998 Civic hoses?
1998 Civic hoses?
Hello all. I need to figure out what kind of rubber hoses are used in two locations: automatic transmission cooling lines ;and the bottom of the brake fluid reservoir?
They appear to be the same size, and Autozone has told me that I can use any generic hose on both. Just wanting to double check because I see some online that are rated for fuel also..
Thanks!
Thanks!
Re: 1998 Civic hoses?
I believe fuel lines are a special rubber, where standard automotive EPDM hoses are not rated for fuel but do handle oil and coolant without issue.
This site provides very detailed information concerning fuel line rubber uses (quick google search):
Tech 101: Fuel-line hose – what you should and should not use | Hemmings Daily
Tech 101: Fuel-line hose – what you should and should not use Hemmings Daily
CALIdelsolSIR
11
11-27-2005 07:25 PM
Seedc2
07-11-2005 12:27 PM
