Atomizer 500lb injectors with hondata ?
Old Jan 28, 2017 | 03:27 PM
070-racing's Avatar
Default Atomizer 500lb injectors with hondata ?
I hope someone can help me here im form the neterlands.
And i own a ek with 1177 hp on 40psi with id2000 injectors .
40psi that was max for the injectors .
Now i wanna have more for 2k17.
So the told me to buy atomizer injectors 500lb or 325lb
But that big injectors can the work with hondata s300 or do i need to buy somthing else to get them to work like a injector driver or something.
Another ecu is not in buget this year.
So im looking for a other option .like big injectors and still hondata.
And does annybody know if a fuel like m5 with a 2345-a weldon pump can deliver me 1300 hp or is that weldon 2345-a not enough .
Hope to here from someone with a good salution.
Thanx mike
Old Jan 29, 2017 | 12:39 AM
1HGEJ2's Avatar
Default Re: Atomizer 500lb injectors with hondata ?
Hello
Ur car is the minion right?
Do u drive a skunk2 ultra? If yes install 8 injectors on the manifold. That will help 8x2000 injector dynamics and u will be safe.
Old Jan 29, 2017 | 10:55 AM
SPOOLINmatt's Avatar
You can use the Honda Injector Driver to drive them. I have one that is LNIB for a good deal!
Old Jan 29, 2017 | 11:48 PM
070-racing's Avatar
Yes my car is the minion yes.
Yes i have the ultra intake so go 8 is better than 4 big ones
And then with the hondata injector driver to run 8 am i correct.
Annybody have feetback on the pump is it enough ?
Old Jan 30, 2017 | 10:26 AM
1HGEJ2's Avatar
Yeah 8 injectors are better then 4. U can run and test 4 ultimate injectors but the most people run 8 injectors, hard wire cable from battery to fuel pump and really really big pumps. Ive seen a cheap combo 3x walbro 450 lph. Fuel pressure about 60-90psi.
Old Jan 31, 2017 | 03:15 AM
The sweed's Avatar
The best thing with hondatas injector driver is that you can drive staged injectors. 4 injectors on low load and 8 injectors on higher load. That way you will have a better idle, throttle response and driveabilety.
Old Feb 2, 2017 | 01:21 AM
070-racing's Avatar
Oke but are 8x2200 cc injectors big enough for 1300hp in m5.
Im looking in to mechanical fuel pump now because 1 2344 would not be enough for m5
TokuiAutowerks
Jun 19, 2008 06:02 PM
96redgsr
Jul 21, 2004 09:46 PM
redturbohatch
Apr 26, 2004 01:15 PM
integracivic94
Dec 30, 2003 06:49 AM
civcexcoupeblack
Dec 16, 2002 01:16 PM
