need help on injectors size?
Old Apr 22, 2004 | 08:52 PM
redturbohatch's Avatar
Default need help on injectors size?
i am in the process of buying some bigger injectors for my car. i want to get rc 750 sat injectors (hondata for tuning). I have a fully built ls/vtec t3/t4 turbo. My question is is 750cc enough for 450 -500whp or should i go with the 1000cc. Rc dont offer 1000cc sat and i dont want to go peak and hold.I think on hondata said that peak and hold injectors dont work as good as sat injectors on honda. i dont want up my fuel pressure too much 45-60 is where i wanna be. I talk to some people and they say that 750 is more than enough for 450- 500 whp. But when i did the flow rate on rc web site it say i need at least 1000cc. is msd injector good?prices? any comment is welcome thank guys
Old Apr 23, 2004 | 11:39 PM
anyone?
Old Apr 24, 2004 | 01:05 AM
11psiTurboSI's Avatar
Default Re: (redturbohatch)
750cc injectors is enough for 450-500hp... from what I remember hold and peak are suppose to work better then saturated injectors but not 100% sure
Old Apr 24, 2004 | 05:13 AM
Boostedcivicsi's Avatar
Default Re: need help on injectors size? (redturbohatch)
I am currently running MSD 96lb injectors, which are 1008cc. They tuned fine, car has stock idle using hondata. I had to get the fuel rail machined to allow for the injector to fit. The MSD injector is a little bigger then the RC. Any local machine shop can fix that problem for you. I have only had mine on for about a week now, but so far, no problems. I would go with the MSD's for the price. I was running RC550's.
Old Apr 24, 2004 | 06:03 AM
FOrSfEd's Avatar
Default Re: need help on injectors size? (Boostedcivicsi)
They should be straight, on an 80% duty cycle they are good up too 476 hp.
Easy formula is
780cc/10.5=74.28
74.3x80=5944
5944/.50=11888
118.8 is the number that each injector can hold.
So you take that and multiply it by four to get your 80% duty cycle on 780 injectors
118.8x4=476
Old Apr 24, 2004 | 10:06 AM
thank guys fot the info .
how much is the msd 98 lbs injector?
Old Apr 24, 2004 | 10:31 AM
FOrSfEd's Avatar
1029cc injectors
Old Apr 26, 2004 | 01:15 PM
bomber's Avatar
Default Re: need help on injectors size? (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">They should be straight, on an 80% duty cycle they are good up too 476 hp.
Easy formula is
780cc/10.5=74.28
74.3x80=5944
5944/.50=11888
118.8x4=476</TD></TR></TABLE>
But arent you using the BSFC for a NA car? The general reccomendation is to use .60-.65 for turbo apps which is going to change these numbers significantly.
deez92
Oct 14, 2021 07:46 AM
TokuiAutowerks
Jun 19, 2008 06:02 PM
96redgsr
Jul 21, 2004 09:46 PM
Anubyss
Jan 9, 2003 09:19 AM
