Help!
Old Sep 7, 2016 | 03:32 PM
chicklet's Avatar
Default Help!
So my speedometer and odometer do not work. Gas, Tachometer, and oil temp work. Same with all the indicators for signals and other things. I have replace the VSS and it still doesn't work. Could it be the wiring going from the cluster to the VSS? Or the cluster itself. Please help ((
Old Sep 7, 2016 | 05:11 PM
holmesnmanny's Avatar
Default Re: Help!
It's likely going to be the cluster.
Old Sep 7, 2016 | 06:31 PM
chicklet's Avatar
Default Re: Help!
So more news about it. I pulled the connection and drove around a bit till i got a code. Then checked it and it said that it had code 17 which is the vss. Which means that the wiring harness for it is good correct? And would i replaced the whole cluster? Or what?
Old Sep 7, 2016 | 06:45 PM
chicklet's Avatar
Default Re: Help!
Am I able to just change the speedo gauge? Or do i have to change the whole cluster.
Old Sep 9, 2016 | 09:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: Help!
Have you done a continuity test on the VSS lead(s) between the cluster and the VSS yet?
If not do so.
What is the MM&Y of car you are talking about and any mods? 94
Old Sep 9, 2016 | 03:32 PM
chicklet's Avatar
Default Re: Help!
If not do so.
I dont have a mulitmeter and its a 93 eg si with a b18a1
Old Sep 9, 2016 | 03:37 PM
chicklet's Avatar
Default Re: Help!
If i get a new cluster do i have to get it programmed?
Old Sep 9, 2016 | 10:32 PM
Default Re: Help!
If you're throwing a code then that's a different story. It means either the vss is bad or you have a wiring issue. If the cluster isn't working that's not going to throw a code. For some reason I read your post as not throwing a code. Try looking at the connectors for the vss it could be rusted up or a wire could have pulled out of the connectors
Old Sep 10, 2016 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: Help!
Before you toss anymore parts at it buy/borrow a multimeter and do a continuity test on the leads, as holmesnmanny mentions make sure plug to VSS is clean and free of corrosion/rust, squirt a little WD40 into the plug to clean it. 94
Old Sep 10, 2016 | 09:29 AM
chicklet's Avatar
Default Re: Help!
I was throwing a code because i unplugged it when i drove it.
Old Sep 10, 2016 | 03:28 PM
chicklet's Avatar
Default Re: Help!
Thanks for your help guys!!! It was the cluster. Bought a new one and it works fantastically!!!
Old Sep 11, 2016 | 08:11 AM
fcm's Avatar
fcm
Old Fart
Default Re: Help!
94
ryrex02
Dec 7, 2010 08:45 AM
purple95
10
Mar 1, 2008 08:47 AM
Midori Green
Jun 25, 2007 03:03 PM
hondaboy4life
Oct 9, 2006 09:35 AM
