92 civic hatch - clunking sound when pressing on clutch pedal?
Old Apr 19, 2016 | 02:08 PM
Lord Dutton's Avatar
Icon5 92 civic hatch - clunking sound when pressing on clutch pedal?
I just recently replaced my flywheel, pressure plate, throwout bearing, etc. on my 92 civic hatch. Afterwards, whenever I press on the clutch pedal I feel an almost grinding like feeling in the pedal. Also, it makes a clunking sound that I managed to get on video.
I can only think that maybe it is from the throwout bearing hitting the pressure plate but I can't be sure.
Also, my clutch pedal now occasionally sticks when coming back up at the halfway point. And I've noticed that even after bleeding the lines until clear fluid came out, 2 days later it is now filled with some kind of black gunk. I can attach a pic later if anyone wants to see.
So, anybody know what is going on here?
Old Apr 19, 2016 | 02:43 PM
fcm's Avatar
fcm
Old Fart
Default re: 92 civic hatch - clunking sound when pressing on clutch pedal?
Check slave cylinder, and connection to push rod. 94
Old Apr 19, 2016 | 04:17 PM
Connection is solid and not slipping at all. Still making sound.
Old Apr 19, 2016 | 10:29 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Re bleed lines till only clean fluid comes out.
How are you bleeding it?
Old Apr 20, 2016 | 06:35 AM
Pumping pedal, loosening nipple, closing back up, repeat while keeping fluid reservoir topped off.
Old Apr 20, 2016 | 06:44 AM
mk378's Avatar
Does it drive OK? Did you grease the pivot points on the clutch lever (where it touches the throwout bearing, where it touches the slave cylinder, and most important, the pivot ball inside the clutch housing). Clutch levers also have been known to crack at the pivot ball point, this eventually causes inability to disengage.
Old Apr 20, 2016 | 06:49 AM
It drives ok except for the clutch pedal sticking sometimes and it has a weird feeling like I'm pushing through some kind of resistance, hard to describe. Other than that, it shifts fine and disengages with no problems. Did not grease where the slave cylinder hits, greased the throwout bearing spine, and I don't think I greased the pivot ball point. Should I take it back out and check that?
Old Apr 20, 2016 | 08:30 PM
bump
Old Apr 20, 2016 | 09:11 PM
Former User's Avatar
Does etc.^ mean that you replaced something else not on the list as well?
What replacement clutch did you install?
Did you follow the service manual procedure?
Old Apr 21, 2016 | 09:23 AM
Installed a regular OEM exedy clutch kit. Did not replace anything not on the list. I supposed the etc. was very unnecessary. I did have to replace other parts like my axel shaft, but thats not pertaining to this.
Old Apr 21, 2016 | 09:52 AM
I didn't see the clutch disc on your list.
Old Apr 21, 2016 | 10:33 AM
Clutch disc was replaced as well.
Old Apr 21, 2016 | 05:09 PM
buuuump
Old Apr 21, 2016 | 05:11 PM
Re-drop transmission. Inspect all clutch related parts. Post pictures. Go from there.
Old Apr 21, 2016 | 05:15 PM
Will do next weekend. Gonna replace clutch master and slave cylinder and try to peer in through the clutch fork hole. If I can't spot a problem then I'll just drop it.
cwadamson
Aug 20, 2018 06:26 PM
Mike ALUM
Honda Civic (2006 - 2015)
May 18, 2011 07:18 AM
vesnarrgh
20
Apr 21, 2011 08:01 PM
trevor72
Oct 26, 2005 04:28 PM
snatchbakman
Oct 26, 2004 11:07 AM
