I should be getting my car back soon and wanted some opinions on HP/Torque in realistic terms. It will go to the dyno once the performance shop is done with it.
Once it is tuned I'll post up the graphs in this thread.
with that clutch...... maybe 400hp max? or youll burn that out real fast on launches etc...
and is wastegate flange on 1 runner or 2 or is it where the collector is? hard to tell from pic.... could play in some boost creep issues, depending on placement of the wastegate....
and yes, ditch the OEM mani....... go victor X for next tune.
A ramhorn *could* allow for a good amount more power though, no? I know people have used the logs for high hp builds, but I figured the performance was mostly from their cam/turbo setup.
yes, but you can only do so much. a ramnhorm would most likely make some more power. but it would also change where to power is delivered. i guessing by the manifold and turbo hes using. he want a more low end to midrange powerband. but just curious how far he could push it.
No. not in this case. Too many times do people use huge manifolds with 1.75" primaries for exhaust volume, with no regard for exhaust velocity based upon the turbocharger used. It makes no sense at all to use something that obnoxious for this sized turbocharger. There would be no benefit.
I remember when just a few years back, people were using Kooks-Style manifolds for GT2860RS turbochargers with .82A/R turbine housings. What a mess.
Check with the Evolution 8-10 guys, and you'd be surprised at the exhaust manifolds they use for huge 600whp stock exhaust manifold builds. They work so well, there's even a specific drag class at the DSM shootout specifically for the stock manifolds. They are barely any larger in runner size or design than a tubular log manifold.
