2.0 gsr dyno tomarrow! predictions and ? on avc-r
ok guys and gals my turbo project is finaly done.... for now. heres the car and the set-up
B18C1
sleeved
84mm 9 to 1's
ib spec rods
knife edged crank
balanced and blue printed
morroso oil pan
endyne breather kit
act extreme clutch
act 12lbd flywheel
obx lsd
carbon coated syncros
26x12x3 FMIC
tranny rebuilt
hasport aluminum mounts with poly bushings
port and polish by portflow
rev hard valves springs and retainers
gsr cams
adjustable cam gears
hondata IM gasket
edelbroc victor X IM
str 70mm TB
hytech header, 3" DP, and dump tube
Tial 46mm waste gate
Tial 50mm BOV
aluminum radiator
3 bar MAP
pt67 p trim turbo
manderal bent 3 inch exhaust
aeromotive fpr
precision 1000cc injectors
walbro 255 pump
island motorsports 500hp axles
all tuned with hondata s200
i think thats all anyways i blew my old motor up Jan. 19 of "05" yes 1 year 1 week ago. i didnt plan on getting a set-up this wild but it just happend one thing led to another and POW i got this. real quick i want to thank all of u great HT guys for helping me out this past year i didnt know to much about boosted hondas when i bought this car i was always an all motor guy but i love the dark side now.
its gets dyno tuned mon or tue cant wait. any predictions? tuner said we prolly wont push it any farther than 15 lbs on pump gas. my guess is 400-450 on 11-15 lbs. ???? we'll see.
i had a ? about the apexi avc-r. lets say my car is tuned for 14lbs and i select 4lbs for first gear. how will my car run proper on 4lbs at WOT when im tuned for 14lbs???? sorry if this is a dumb question but i havent found anyone or anything to help me out with this ? so its time to ask. thanx guys
B18C1
sleeved
84mm 9 to 1's
ib spec rods
knife edged crank
morroso oil pan
endyne breather kit
act extreme clutch
act 12lbd flywheel
obx lsd
26x12x3 FMIC
tranny rebuilt
gsr cams
hondata IM gasket
str 70mm TB
Tial 50mm BOV
aluminum radiator
3 bar MAP
pt67 p trim turbo
aeromotive fpr
walbro 255 pump
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (mattcivic)
First of all, sick setup.
Second of all, I'm sure your car will run fine at 4 psi, since it's tuned for 14 psi. It has to go through 4 psi to get there.
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (boostincoupe)
it wont be hella rich only hitting 4lbs? this just confuses the hell out of me. thanx
It will run perfect (assuming the tune is right) at 4 psi, wot. The fuel delivery is dependant upon boost, so whether you are running 6 psi, 10 psi, or whatever, the af will stay wherever you tuned it at.
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (Muckman)
says 84mm up there
Very similar to my setup, so I'm excited to see what you make. I have a 85mm b18a w/9.1 JE's, crower billet steel rods, b18c1 head, skunk 2 stage 1 na cams, ferrea stock sized valves, skunk 2 dual springs, crower titanium retainers, and a will be tuned on 110 octane. I'm hoping for 550 whp
Modified by slowteg550 at 9:32 PM 2/5/2006
official honda whore
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (Turbocivic94)
very nice car and very nice build... as for you running 4lbs, you wont be able to run any less boost then what your wastegate spring is... so if you have a 7lb spring the least amount of boost you can run is 7lbs...
also when the tuner tunes the car he will start tuning at the lowest amount of boost and progressively turn up the boost and tune so that way your cels in your maps are all tuned and you will be able to run from lowest set boost to the highest he tuned without having to worry
brian
brian
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (SpeedingHatch)
ahh i see how it worx now. i dont know what spring i have in my WG but thanx for explaining that. i didnt get a phone call today on the car so im guessing its gunna be tomarrow that it gets tuned. and thanx for the compliments on the car and the build. i will post the numers as soon as i get them and then get you guys a pic of the dyno graph as well. im picking the car up friday evening ill let ya know how i like it.
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (slowteg550)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg550 »</TD></TR><TR><TD CLASS="quote">says 84mm up there
Very similar to my setup, so I'm excited to see what you make. I have a 85mm b18a w/9.1 JE's, crower billet steel rods, b18c1 head, skunk 2 stage 1 na cams, ferrea stock sized valves, skunk 2 dual springs, crower titanium retainers, and a gt3561s, will be tuned on 110 octane. I'm hoping for 550 whp </TD></TR></TABLE>
stage 1 NA cams how do u like those? i have a buddy with stage 1's hes gunna upgrade to stage 2's soon would using his old stage 1's be a good idea? what about a set of turbo cams any recomendations?
Shooting Star
hey man im gonna be excited to see what you get out of it. I have heard from several people that stage 1 n/a cams are better than turbo cams I dont know though.
Re: (vtecspeed1320)
For the most part, ITR or Skunk 2 Stage 1 NA cams (both are pretty much the same thing) are two of the better cams that are easy to get your hands on for a high hp boosted application. I hear of gains from 30-90 HP over GSR cams w/ITRs or skunk 2 s1's.. I don't have my setup together yet, so I can't tell you personally how I like them..
Re: (slowteg550)
hhmm ill have to see. i talked to my buddy and hes not upgrading to stage2's hes supercharging his car and thinks that his stock gsr cams will work better. i sware a long long time ago i was looking into supercharging a car of mine and jackson says to stick with yer stock cams. anyways still no call from Reid if he doesnt call me by 5 tomarrow im gunna get a hold of him and see whats up. if i can get a ride down i migh go pick it up wed but i work early and its a long drive there and back. total of 5 hours!
Shooting Star
Thats what I have heard about the skunk 2 stg 1's its a big increase in power. I would do it if i was you. Especially if your looking for super solid numbers.
1 Post
Wow, you have done an excellent job of building that GSR! Good luck with the tuning, after its tuned I would love to see some vids with the front end on it and ~400hp propeling it
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (jfoster)
Well i called on the car today Reid said they were still just street tuning it and he will call me when its done expletive! im not mad at reid or the guys at Kaizen im just gettin ancy. as soon as i know anything ill let u guys know sorry to get yer hopes up.
Well the car is an animal,.... feels very good... wish we could do a race gas tune for you now, but I guess we can wait until spring, if you insist.
As for the AVC-R, yes it does have to go through 4psi to get to 15, but since the wastegate spring is set at 15 psi, that is the lowest load I can tune for throughout the entire RPM range at WOT. I have made the lower load fuel curve match in shape to the higher load (15psi) fuel curve, and estimated the percentage of fuel across the RPM range at the lower load (4psi)....
Right now the car runs perfectly, we're revving to 8,500 RPM because I don't think it makes a whole lot more power beyond that, but we'll see. We might raise it to 9,000 if it is still making power, we'll see when we put it on the dyno... 10 A.M. tomorrow (Saturday 1/28) weather permitting.
Re: 2.0 gsr dyno tomarrow! predictions and ? on avc-r (Hondaddict)
ahh there ya go people. i guess give me a call in the morning or ill call ya at like 3 or so to see whats up. i hate being so far from the shop its a pain getting a ride out there. thanx again guys.
