GSC T1 VTEC RPM
This. If you really want to know where to set your cross, though, set it to 1000 RPM (basically always on), do a pull on the dyno, then set it to 10000 (basically always off) and do a pull. Where the HP lines cross between the two graphs, that's where you want to set your VTEC engagement.
In a pinch, the "Virtual Dyno" software can help with things like what you're looking to do. Don't put any faith in the numbers it spits out, but it does give you a curve to work with.
i will give virtual dyno a test :D thanks, hopefully it can open logs from VEMS with out to much hassle :D
gutted
30
Jan 27, 2004 08:17 AM
