VTEC Crossover
Old Aug 25, 2003 | 08:50 PM
rocket256's Avatar
Default VTEC Crossover
where should your vtec crossover point be? under 5000 rpm or over 5000 rpm for more midrange power?
Old Feb 10, 2005 | 05:37 PM
rocket256's Avatar
Default Re: VTEC Crossover (rocket256)
bump
Old Feb 10, 2005 | 05:52 PM
adseguy's Avatar
If you take it on the dyno you do one pull with VTEC set at like 9000rpm (so it never engages) and one pull with VTEC set at 2000RPM (so it's always engaged. Where ever you start making more power (i don't know it's HP or torque that you look at...maybe both ) with the VTEC engaged is where you set the VTEC at minus 100-200 rpm.
Old Feb 10, 2005 | 05:55 PM
_gurusan_'s Avatar
Default Re: VTEC Crossover (adseguy)
werd
Old Feb 10, 2005 | 06:13 PM
rocket256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">If you take it on the dyno you do one pull with VTEC set at like 9000rpm (so it never engages) and one pull with VTEC set at 2000RPM (so it's always engaged. Where ever you start making more power (i don't know it's HP or torque that you look at...maybe both ) with the VTEC engaged is where you set the VTEC at minus 100-200 rpm.</TD></TR></TABLE>
why minus 100-200 rpm?
Old Feb 10, 2005 | 06:57 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">If you take it on the dyno you do one pull with VTEC set at like 9000rpm (so it never engages) and one pull with VTEC set at 2000RPM (so it's always engaged.</TD></TR></TABLE>
Do this and set vtec where the torque curve crosses.
Old Feb 11, 2005 | 05:22 PM
rocket256's Avatar
Default Re: VTEC Crossover (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
so that is how you get more midrange?
Old Feb 11, 2005 | 05:57 PM
Just Checking In's Avatar
That is the rpm at which the higher lift and longer duration profile makes the same amount of power as without. Rpm's below that point you would be at a loss and rpms beyond are beneficial. We are not choosing power at a specific point, rather we are dictated this point by the physics of the engine where we can make a combined power curve with the largest area underneath.
Modified by Just Checking In at 7:08 PM 2/11/2005
Old Feb 11, 2005 | 07:34 PM
rocket256's Avatar
Default Re: VTEC Crossover (Just Checking In)
nicely put
Old Feb 12, 2005 | 03:09 AM
dnbruut's Avatar
qoutei don't know it's HP or torque that you look at...maybe both
you really dont have a clue do you? ever seen a dyno where @ any rpm the torque rises and the hp drops???
FlsFinest
Jul 21, 2005 01:33 PM
gutted
30
Jan 27, 2004 08:17 AM
Nospace
Dec 29, 2003 01:14 PM
youngvedder
Jun 17, 2003 02:29 PM
1 2 NV
Apr 12, 2003 10:01 PM
