Help!, my car died suddenly while in park, now it wont turn on....
Old Nov 6, 2002 | 09:07 AM
Ideal's Avatar
Default Help!, my car died suddenly while in park, now it wont turn on....
I was chilling in my car listening to music in my car, it was on, then it just sputtered and my rpms dropped 0, so it was basically off, I turned it off, tried it again, and still nothing, just makes that chirping sounds, like its starting... but it just doesnt fully turn on. Need help guys, it wont turn on and im at my college....help!!
Im thinking maybe I just need a jumpstart, but if the car was on when it died, it should have been powered by the alternator, i checked my spark plugs, wires, everything seems to be in order, not sure what to do now, help!
-Jon
Old Nov 6, 2002 | 09:13 AM
Stew Pidasso's Avatar
Default Re: Help!, my car died suddenly while in park, now it wont turn on.... (Ideal)
Does the engine turn over or when you turn the key nothing happens?
Old Nov 6, 2002 | 09:16 AM
Ideal's Avatar
Default Re: Help!, my car died suddenly while in park, now it wont turn on.... (Stew Pidasso)
im not sure what you mean by turn over....im not to car savey at the moment.
edit: It just makes a sound like, its trying to turn on, and sometimes it even shakes like its about to turn but it just doesnt turn on.
[Modified by Ideal, 10:17 AM 11/6/2002]
Old Nov 6, 2002 | 09:25 AM
RotaryBzzz's Avatar
FYI - campus security should have a car that can come out and jump you for free. If you have 20th century insurance, they'll jump you or tow (up to 7 miles) for free.
edit: how many miles on the alternator now? total on the car?
[Modified by RotaryBzzz, 10:26 AM 11/6/2002]
Old Nov 6, 2002 | 09:26 AM
Ideal's Avatar
Default Re: Help!, my car died suddenly while in park, now it wont turn on.... (RotaryBzzz)
Well, I have triple A, do you guys think maybe all I kneed is a jump?
edit: I dont think the alternator has ever been changed, the car has about 120k
[Modified by Ideal, 10:26 AM 11/6/2002]
RotaryBzzz's Avatar
that will get you home prolly...but that won't address the underlying issue...hmmmm
edit: that's still a young alternator (for japanese) then.
edit2: oh, btw, calling campus security will prolly be faster than going thru AAA if you've got somewhere to go...
[Modified by RotaryBzzz, 10:27 AM 11/6/2002]
[Modified by RotaryBzzz, 10:28 AM 11/6/2002]
Old Nov 6, 2002 | 09:28 AM
Ideal's Avatar
lol, 120,000 is young?
RotaryBzzz's Avatar
yah!
Old Nov 6, 2002 | 09:29 AM
Ideal's Avatar
It is a 93, ive heard of a main relay problem with it, is it a possibilty?
Old Nov 6, 2002 | 09:30 AM
RotaryBzzz's Avatar
this is the line recall/TSB data for your 93 Accord.
Bulletins for 1993 Honda Accord L4-2156cc 2.2L SOHC
Safety Recalls
TSB Number Issue Date TSB Title
93019 JUN 93 Recall - Rear Seat Belt Retractor Sensor
General Recalls
95049 DEC 95 Campaign - Defective Distributor
93020 APR 93 Campaign - Rear Seat Belts Lock When Parked At Angle
Service Bulletins
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-089 OCT 00 Supplemental Restraint System - Inspection
99-018 APR 00 Required Special Tools And Equipment,
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
97-015 DEC 99 Service Publications - Availability & Ordering
99-037 MAY 99 Front Balancer Shaft Oil Seal Installation Tool
99-030 MAY 99 Recommended Materials
98-074 DEC 98 Engine - Hesitation or Stumble.
19_1-04 OCT 98 Interior - KRYTOX(R) Fluid Applications
98-051 AUG 98 Special Tool Loan Program
98-026 APR 98 Audio Unit - Antitheft Code Labels
98-018 APR 98 CV Joint Boot - Band Tool
98-001 FEB 98 Engine/Transmission - Hydraulic Lift Truck usage
90-007 MAY 97 90-007 - 05/27/97
86-020 MAY 97 Brakes - Disc Refinishing Procedure
97-027 MAY 97 Tools - Denso HLD-100 Halogen Leak Detector
97-028 MAR 97 Body - Minor Paint Finish Repair
97-018 MAR 97 Suspension - Rear Wheel Bearing Noise
97-020 MAR 97 Tools - New Fuel Pressure Gauge and Replacement Parts
96-046 OCT 96 Keyless Entry - Transmitter Programming Information
96042 SEP 96 Tools - Power Steering Pressure Gauge
93033 JUN 96 Seat Belt - Tongue Stopper Button Broken
89029 MAY 96 Radio - Warranty Exchange/Out Of Warranty Repair
89004 MAY 96 Required Special Tools & Equipment
96014 FEB 96 Tools - Belt Tension Gauge Calibration and Repair
96005 JAN 96 Engine - Idle Vibration or 'Click'
91030 JAN 96 Seat Belt - Slow to Retract
92012 JAN 96 Seat Belts - Warranty Replacement Policy
89029 DEC 95 Radio - Unit Diagnosis
90007 AUG 95 Service Publications and Supplies
95024 JUL 95 Airbag - Cable Reel Holding Fixture
95020 JUN 95 A/C - Converting R-12 Systems to R-134a
89029 MAR 95 Radio - Unit Exchange/Repair
93011 JAN 95 Alignment - Premature/Irregular Front and Rear Tire Wear
ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
94043 DEC 94 Charging System - Alternator Bearing Noise
93011 OCT 94 Alignment - Premature/Irregular Front And Rear Tire Wear
94036 OCT 94 Radio - Bose Amplifier Remanufacturing Program
90014 SEP 94 A/T - Remanufacturing Exchange Program
94025 AUG 94 Steering - Wheel Oscillates or Has a Shimmy
88012 AUG 94 Tools - Exacta Code Key Cutter
93005 JUN 94 Body - Doors Hard To Open Or Close
92004 JUN 94 Steering - Power Steering Rack Squeaks
91010 JUN 94 Window - Rattles While Partially Opened
94011 MAY 94 Radio - Poor Reception Or Interference
94004 MAR 94 Brakes - Parking Brake Does Not Release Fully
91017 FEB 94 Sunroof - Rattle When Partially Open
91008 JAN 94 Lighting - Buzzing During Turn Signal Lever Operation
88023 DEC 93 Battery - Testing Procedure
93046 OCT 93 Mirrors - Rearview Mirror Tension Adjustment
ATRATB191 OCT 93 A/T - Failsafe Modes
ATRATB187 OCT 93 A/T - Trouble Codes
93034 SEP 93 Engine - Noisy Water Pump
93027 JUL 93 Doors - Wind Noise From Mirror or WIndow Glass
93017 MAY 93 Radio - Popping Noise In Speakers
93018 APR 93 Seat Belt - Retractor Sensor Installation, Rear
93015 MAR 93 Steering - Column Squeak
93013 FEB 93 PDI - Protective Plastic Film (Acid Rain)
92026 FEB 93 Radio - Trunk Unit CD Changer Magazine Won`t Eject
91019 FEB 93 Emissions - Label Replacement Information
92045 NOV 92 Body - Paint Codes
92041 NOV 92 Engine - Vehicle Fails State I/M Emission Test
92040 NOV 92 Tools - Crankshaft Pulley Holder
91001 NOV 92 Window - Noise While Raising or Lowering Window
92036 OCT 92 Radio - Poor Reception or Interference On AM Band
87006 OCT 92 PDI - Shipping Wax Removal Update
90009 OCT 92 PDI - Steering Wheel Vibrates
92027 SEP 92 PDI - Vehicle Storage
ATRATB132 SEP 92 A/T - Intermittent Electrical Problems
ATRATB125 AUG 92 A/T - Bind-Up In 4th Gear
ATRATB116 JUN 92 A/T - Noise Going Into or Out Of Reverse
88037 MAR 92 Paint - Damage Due to Acid Rain
ATRATB090 JAN 92 A/T - 4 Speed Pressure Specifications
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
91019 JUN 91 Emissions - Underhood Label Replacement Information
89004 FEB 91 Special Tools - Equipment, and Service Manual
86027 DEC 90 Tools - Engine Stand and Adapter Information
90037 DEC 90 Tools - Instructions For New Ball Joint Tool
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
83005 AUG 83 Vehicle - Engine/Chassis Serial Numbers
[Modified by RotaryBzzz, 10:33 AM 11/6/2002]
[Modified by RotaryBzzz, 10:34 AM 11/6/2002]
Old Nov 6, 2002 | 09:38 AM
Yes it is a possibility but I think mostly it happens when it's warmer out.
This thread discusses it. https://honda-tech.com/zerothread?id=253440
Old Nov 6, 2002 | 09:39 AM
Ideal's Avatar
Can i still go in to have the recalls fixed? what is/are the tsb datas?
Old Nov 6, 2002 | 09:45 AM
Some more possibilities... https://honda-tech.com/zerothread?id=293018
https://honda-tech.com/zerothread?id=271018
https://honda-tech.com/zerothread?id=243993
https://honda-tech.com/zerothread?id=220726
https://honda-tech.com/zerothread?id=205895
https://honda-tech.com/zerothread?id=186747
Old Nov 6, 2002 | 09:46 AM
RotaryBzzz's Avatar
yes...general/ safety recalls will always be honored for free by honda. TSB's no. Call before you go and mention what you want to have done w/ the recall # in hand. They might ask for your VIN number which they would run (hopefully) and if the previous owner already did them...they (honda service) would tell you and would save you a trip.
TSB = techical service bulletin. This is what mechanics (honda and others) will use to help them diagnose problems and fix things right.
[Modified by RotaryBzzz, 10:47 AM 11/6/2002]
Old Nov 6, 2002 | 09:47 AM
Ideal's Avatar
how do i also check for spark, im unsure how to do so...
RA61825
13
Aug 25, 2007 02:57 PM
fkguitar
Aug 6, 2005 10:03 AM
Obese
Jul 23, 2005 11:30 AM
mystikteg92
Mar 23, 2004 03:43 PM
