wobbling distributor
Old Nov 9, 2015 | 02:18 PM
sr20paisa's Avatar
Default wobbling distributor
I just re-installed my distributor and it's wobbling or shaking quite a bit, the cam holder that bolts up with the distrbutor was pretty hot to the touch, anybody know whats up?
sr20paisa's Avatar
Default Re: wobbling distributor
it's a d16a6 btw
Old Nov 9, 2015 | 03:57 PM
sr20paisa's Avatar
.....it's starting to really **** me off
Old Nov 9, 2015 | 09:21 PM
sr20paisa's Avatar
bump for help
Old Nov 10, 2015 | 03:35 PM
sr20paisa's Avatar
bump
Old Nov 10, 2015 | 04:48 PM
whited's Avatar
CRX God
No bumping in tech forums. These are slower that GDD. Can you post a picture? What is the distributor model number?
Old Nov 11, 2015 | 07:37 AM
BLU CIVIC's Avatar
Track Advocate
It wobbles when bolted in? I'm kinda confused
Old Nov 11, 2015 | 07:40 AM
burnoutboy's Avatar
The Credible Hulk
Sounds like the end cap or the cam could be damaged if it's actually bolted down tight.
Are you sure you seated the dizzy correctly and it's not 180 degrees out?
Old Nov 11, 2015 | 08:55 AM
sr20paisa's Avatar
yep, i put the distributor on right, i torqued all the cam caps to spec. i'm pretty sure it's end cap next to the distributor- going to check that right now
Old Nov 11, 2015 | 08:56 AM
sr20paisa's Avatar
put it like this, it shakes mre than the motor does
Old Nov 11, 2015 | 08:59 AM
burnoutboy's Avatar
The Credible Hulk
If it's bolted tight to the head I don't understand how exactly it can do that either.... vid maybe? Pics at least?
Old Nov 11, 2015 | 09:02 AM
sr20paisa's Avatar
i'll post the vid up in a bit
Old Nov 11, 2015 | 03:24 PM
sr20paisa's Avatar
Old Nov 11, 2015 | 04:50 PM
sr20paisa's Avatar
you can hardly see it wobbles
Old Nov 12, 2015 | 09:39 AM
burnoutboy's Avatar
The Credible Hulk
I can see the wobble... it doesn't look like it's bolted on tight.
What's with the weird bolt with the double washer on the top? You sure you have the right hardware securing it on there. I don't think I've ever seen a dizzy bolt with a phillips (or JIS) head on it.
Old Nov 12, 2015 | 05:20 PM
sr20paisa's Avatar
i wouldnt know, the car came like that
i'm still not too familiar withthe ed chassis yet
Old Nov 12, 2015 | 08:39 PM
Tyson's Avatar
have you taken any steps to diagnose this?
like opening the cap?
checking the rotor?
checking if theres play in the shaft?
Old Nov 12, 2015 | 08:44 PM
sr20paisa's Avatar
checking the rotor?
no, my main concerns was the bolts
will check though just in case
Old Nov 14, 2015 | 03:40 PM
sr20paisa's Avatar
so i finally got around fixing this, it was the key on the distributor which was on the wrong way, so i flipped it 180 degrees and and then the wobbling went away
Rusbin
May 19, 2018 09:49 AM
RiPe14yoU
May 16, 2017 02:44 PM
warfield21
Apr 15, 2017 12:26 PM
stealth89hatch
Sep 19, 2004 02:06 PM
