wobbling distributor
I just re-installed my distributor and it's wobbling or shaking quite a bit, the cam holder that bolts up with the distrbutor was pretty hot to the touch, anybody know whats up?
Re: wobbling distributor
yep, i put the distributor on right, i torqued all the cam caps to spec. i'm pretty sure it's end cap next to the distributor- going to check that right now
The Credible Hulk
I can see the wobble... it doesn't look like it's bolted on tight.
What's with the weird bolt with the double washer on the top? You sure you have the right hardware securing it on there. I don't think I've ever seen a dizzy bolt with a phillips (or JIS) head on it.
i'm still not too familiar withthe ed chassis yet
so i finally got around fixing this, it was the key on the distributor which was on the wrong way, so i flipped it 180 degrees and and then the wobbling went away
stealth89hatch
09-19-2004 02:06 PM
