Crank-no start
Old Nov 1, 2015 | 01:39 PM
Tony Piatt's Avatar
Default Crank-no start
Hey guys. I have a 1993 del sol si D16z6. I webt to dinner and drove home. I went to leave a couple of hours later and my car wouldnt start. It would crank but not start. Ive replaced the dizzy, cap, and rotor button. New plugs and wires and main relay and still nothing. Im stumped as to what it could be. Any help would be appreciated.
Old Nov 1, 2015 | 01:41 PM
Tony Piatt's Avatar
Default Re: Crank-no start
I also dont get any fire at the spark plugs.
Old Nov 1, 2015 | 03:15 PM
tamboo's Avatar
10 Year Member
Starting Problems
Old Nov 1, 2015 | 07:53 PM
Tony Piatt's Avatar
Ive done everything it says on there and it lead nowhere. Im thinking its the ignition cause when the car was running i could take the key out while driving
Old Nov 1, 2015 | 08:26 PM
Former User's Avatar
^Unlikely
Does the fuel pump prime?
Does the CEL remain on steady with key in ON(II)?
Old Nov 1, 2015 | 09:38 PM
Tony Piatt's Avatar
Ive had the car for 6-7 months and have never heard the fuel pump prime and the check engine light is on through all three ignition stages but the fuel pump wouldnt cause me not to get spark at the spark plugs
Old Nov 2, 2015 | 02:03 AM
delsolintegra's Avatar
Did the replacement dizzy have a good coil and ignitor?
If you have a friend with a similar car swap out the dizzy and ECU from a known good running car.
Check the ground wire connection at the thermostat housing. This is the ground point for the ECU.
Old Nov 2, 2015 | 02:37 AM
W95civicEXcoupe's Avatar
GDD's Resident Derp
That'll do it, every time.
Crank, no start? At least it is cranking, so, there is hope.
You need spark, fuel, and compression (timing, air, no bent valves, proper firing and again, timings to combust said air/fuel mixture) to start the car.
If any of these are lacking then it will not start.
No fire = no spark = that will cause the car not only to not start, but stop running at any given point in time. Same for no fuel. Same for if your timing or valves go on you, somehow.
Old Nov 2, 2015 | 05:13 AM
Tony Piatt's Avatar
Everything in the dizzy is new. I bought a coil before replacing the dizzy.
Old Nov 2, 2015 | 05:32 AM
GDD's Resident Derp
Did you check for fuel when the car is cold? There is a nut that you can loosen that should spray fuel when the key is turned. Again, please make sure engine is COLD ..
If you can make it to :25, this video is specific Honda, and addresses this topic. (Main Relay, and fuel test.)
Old Nov 2, 2015 | 06:29 AM
Answer this^ question, and pull the CEL codes and post them.
Old Nov 2, 2015 | 01:02 PM
Tony Piatt's Avatar
Ill check to see if the fuel pump primes but im not able to pull the cel codes due to my D4 light being out
Old Nov 2, 2015 | 01:55 PM
Irrelevant to CEL codes
Old Nov 2, 2015 | 07:35 PM
Tony Piatt's Avatar
How do i pull cel codes on an obd1 without that light?
Old Nov 2, 2015 | 07:40 PM
JarvisW's Avatar
Sol to Sol
read the FAQ, the CEL blinks not D4
Old Nov 2, 2015 | 10:05 PM
Tony Piatt's Avatar
All the videos i have watched about pulling codes off of a del sol or civic have shown the D4 blinking after jumping the obd1 test connection
Old Nov 3, 2015 | 12:35 AM
93-95 del sols are OBD 1 and the cel light flashes.
I think the 96-97 del sols are as you describe, the D4 light flashes (OBD 2? )
Old Nov 3, 2015 | 12:15 PM
Tony Piatt's Avatar
Ive jumped both service connections before when the car first stopped running and nothing blinked or anything but the cel stayed on
Old Nov 3, 2015 | 12:46 PM
GDD's Resident Derp
Can you try this?
Apologies on being deliberate, but, maybe you missed something...
If you have no codes, it will stay on.
*The video also suggests that your ECU itself could be damaged.
Old Nov 3, 2015 | 02:14 PM
JarvisW's Avatar
Sol to Sol
Both? there's only one you need to jump. its under the glove box
READ THE FAQ!
Old Nov 3, 2015 | 05:54 PM
Tony Piatt's Avatar
Ive pulled my ecu out and opened it up and nothing looks burnt or broken. And yes both because one is a dealer service connection and the other is for non dealer
Old Nov 3, 2015 | 07:26 PM
Two requests and still no answer:
Also:
Does the CEL turn on and stay on both with and without the 2P service connector jumped?
Post a picture of the service connector you are jumping to pull codes.
pmey
May 26, 2009 01:11 PM
slavagc8
15
May 26, 2009 06:17 AM
quad
20
Mar 14, 2007 05:16 AM
masterp
Dec 5, 2006 02:26 PM
vietjdmboi
Mar 8, 2005 06:33 PM
